Test environment issues
TomMar1
Level 7
Level 7
I set up a new test environment for v12 UCM, IMP and UCCX.  When trying to connect a user via Jabber I get cannot communicate with server.  I have installed Jabber with the UPN discover disabled and am using a non domain machine.  I set the Advanced Settings in Jabber to use the new FQDN of the IM&P server.
I generated the Jabber problem report, and I see "Failed to retrieve user credentials for profile"
Any help would be greatly appreciated.
Jaime Valencia
Can you login to the self-care portal?
Are all the user / device / line associations properly configured?
java
if this helps, please rate
Yes, I am able to log into the self care portal.
I have double checked all the user association are present.
Trying with an IP Communicator device and am having similar issues registering a device against the new UCM.
So I neglected to activate the necessary service activation settings.  I also needed to create and assign a service profile setting.  This allowed me to get a CSF device registered to UCM, still having issues with the CIPC device though.
CIPC last I used it requires the device name to be exactly as expected in the UCM. You can use something generic like <USER>CIPC, this may cause call recording or CTI problems. It doesn't learn anything from the network in my experience, and required you to set the TFTP servers manually by running it as administrator and specifying where it should talk to.
