UCCX add certificate using java
e23
Frequent Visitor
Frequent Visitor
Hello, we have a certificate installed on a soap server and we are trying to connect to it using java and uccx editor,
I would like to know if it's possible to do it using java.
When we added the certificate files to the uccx it returned handshake failed exception.
2 Accepted Solutions
I hope, I got it right:
UCCX connects to a SOAP server, and while connecting UCCX should verify the certificate of the SOAP server.
If yes, then you need to upload the certificate of the SOAP server and / or the CA-certificate into UCCX (probably into "tomcat-trust" store) via OS administration GUI.
Nothing about certificates is done in the UCCX editor, this is only for the script editing.
You are correct, the certificate chain needs to be added to the tomcat-trust store in CCX.
Response Signature
b.winter
What are you trying to do? From your post, I don't understand what you are doing or what you are trying to achieve. Your post is very confusing.
e23
Frequent Visitor
Frequent Visitor
I have to files, p12 and jks + password
The target is to validate the certificate from UCCX side to connect to the soap server.
I just want to know if i should do it in java (in UCCX Editor) or on UCCX level.
if i have to do it in java what are the steps that i should follow.
Response Signature
