using Jabber on CME
tato386
Level 6
Level 6
I would love to start using jabber at our office but we are running on a UC520 platform.  Seems like Jabber doesn't _officialy_ support CME but at the same time this doesn't mean it won't work, does it?
Anybody have any experience running jabber on UC520?  All Tips, suggestions and or advice would be greatly appreciated.
Diego
5 Replies 5
Leonardo Santana
Hello Diego,
Cisco Jabber is supports the following:
Table 2. Platform Support and Compatibility for Cisco Jabber 8.6 for iPhone
Feature
Supported Product
Version Number
Telephony integration
Cisco Unified Communications Manager
7.1.5, 8.0.3, 8.5, 8.6, and 9.0 (refer to release notes for exact versions)
Cisco Unified Communications Manager Express
8.6 and 8.8
Jabber is supported on CME on the versions above.
Take a look on the datasheet:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps11156/data_sheet_c78-658146.html
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6789/ps7290/ps11678/data_sheet_c78-649887.html
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Hello Leo:
Interesting that the iPhone version mentions CME but the Android version does not.  That is why I had the idea that Jabber did not support CME since we are interested in Android version.
Do you think it is just an oversight?  Weird, no?
Diego
Its not supported or isnt tested yet.
You can try to open a case on PDI but i think that will be the answer.
Leonardo Santana
Leonardo Santana
Thanks Leo.  I think I will take Paolo's suggestion but move the thread to Jabber Client and try my luck over there.
Thank you.
paolo bevilacqua
Wrong forum, post in "small business voice - UC500". You can move your post using the actions panel on the right.
