03-11-2018 11:53 AM - edited 03-17-2019 07:23 PM
Is there a VESA standard wall mount that can be used with the Cisco Spark 55" Board? SPARK-BOARD55-WMK= listings run from $175-$714 and all seem to be the same or very similar VESA steel wall mounts for a 55" LCD.
Thanks ahead of time for the time and efforts.
Warm Regards,
Dutch
03-11-2018 01:44 PM
Michael
Cisco decided not to use the standard VESA mount because the unit is different from a regular video endpoint and folks tend to put pressure on the unit since its a white board device and can cause issues in regions earth quake prone too
AVTEQ has choices for this
05-15-2018 08:47 AM
I had the same question at the beginning. However, it turned out that the board has to be mounted fixed (not variable) and at a certain height to support whiteboarding and a correct conference view. Additionally the board is quite heavy which automatically sorts out many of the third party VESA solutions. If you need something special you will have to probably engineer it based on the supplied wall mount.
05-16-2018 10:48 AM
Yes i also recently got the new Cisco Webex board 55 and hoping to get a cheaper mount from Amazon or other place... Nope... The screw layout is at the 4 edge of the screen... After multiple researh i end up biting the bullet and got the Original Spark boad Stand from Cisco.
This is the mount i end up getting ( Cost more then a decent 55" 4K TV) ....https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/spark-board/installation-guide/spark-board-55-with-floor…
