Webex causes Internet explorer to crash Faulting module path: C:\ProgramData\WebEx\ieatgpc.dll
glennkelly
When the Webex plug-in launches in IE, it causes IE to crash with the dialogue box "Internet explorer has stopped working"
The event log shows
Faulting application path: C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE
Using
IE version 11.0.9600.19035 update version 11.0.65
Webex Meeting Centre 32.12.5.2
Windows 7
Full error from Event viewer
Faulting application name: IEXPLORE.EXE, version: 11.0.9600.19036, time stamp: 0x5b077e91
Faulting module name: ieatgpc.dll, version: 2.1.0.11, time stamp: 0x5ab3535e
Exception code: 0xc0000005
Fault offset: 0x00019669
Faulting process id: 0x25e8
Faulting application start time: 0x01d413767de15240
Report Id: 106e359f-7f6a-11e8-870a-e4a4713b156d
Can anyone suggest a fix for this please?
Glenn
Ratheesh Kumar
Hi there
Could you try this and see that helps ?
Step 1: Open Internet Explorer
Step 2: Tools > Internet Options > Advanced > Security >
Step 3: Uncheck "Enable memory protection to help mitigate online attacks"
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Thansk for the reply Rath!, however we do not see this setting in IE 11, and its not in Group Policy either so its not hidden.
@Ratheesh Kumar wrote:
Hi there
Hope this helps!
Cheers
Rath!
