Webex click to call popup
mthijssen
When you use the Click-to-call feature on an Windows PC with Webex:
for example use one of the commands below:
tel:+31612345678
webextel:+31612345678
Build a Click-to-Call Shortcut Using Adaptive Cards in Webex | Webex Developers Blog
You get an popup in Webex before the call is placed:
Is it possible to disable this popup?
So that the call is directly placed by Webex when you use click to call?
bbk
Did you find a solution for this ? As I have a customer who is aking for the same.
Unfortunately no, there is no solution yet.
