Hi there
I dont think there is a way other than keeping an eye on the audio waves of participants.
Mute or Unmute Yourself or Others
As a participant:
In the Participants panel, select Mute
or Unmute
to mute or unmute your own microphone.
![](https://www.cisco.com/c/dam/en/us/td/i/esp/icons/icon-notes.svg) |
When Cisco Webex Meetings (Windows, Mac) and Cisco Webex Events (Windows) users mute or unmute from their headsets, they will also be muted or unmuted in the Participants panel. Similarly, muting or unmuting from the Participantspanel also affects their headsets.
As a host:
To mute everyone as they join, from the Participant menu, select Mute on Entry.
To mute or unmute everyone but you, from the Participant menu, select Mute All or Unmute All.
To mute or unmute specific people, in the Participants panel, hover your mouse over their name, and then select Mute
or Unmute
Webex Meetings participants can always mute or unmute themselves regardless of mute on entry being enabled or being muted by the host.
https://help.webex.com/en-us/nc2bqt1/Tips-and-Tricks-for-Using-Audio-with-Cisco-Webex-Meetings-Suite
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
