What is the difference between Jabber and Movi client ?
KY_
Level 4
Level 4
Hi Everyone,
I need to clarfy someting and I will deploy  a jabber project next month.
What is the difference between cisco jabber client and Movi (Cisco video for Telepresence) I heard that  movi is formerly Tandberg client.
Where we need to use movi ? Have it still supported by Cisco ?
Can you please give me brief information about movi.
Do I need install on customer PC  both of them (jabber and movi)
Thanks & Regards
Jaime Valencia
Have you reviewed the data sheet of both products??? Assuming you're familiar with at least one of them, reviewing the data sheet will provide you with an overall understanding of each, and the features.
java
if this helps, please rate
Yes Jaime .!
I look at the datashet but also  I"m asking this question as you can see   above Does it still supported ?
Why do you asking me this question ?
I checked following link but I"m trying to undersatand difference between both of them.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/jabber-windows/data_sheet_c78-704195.html
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/jabber-video-telepresence-movi/data_sheet_c78-628609.html
Making sure you have done your due diligence, and reviewing the relevant material online.
http://www.cisco.com/c/en/us/products/collaboration-endpoints/jabber-video-telepresence-movi/eos-eol-notice-listing.html
You should have noticed many differences between them, specially that one is meant for CUCM/IM&P and the other one for TMS/VCS registration.
You should NOT be positioning MOVI, Jabber is the replacement. On the right side of the data sheet link you posted, are the EOS/EOL notices for MOVI as well.
Finding if a product has gone EOS/EOL is extremely easy, just google: < product name > + eos OR eol
java
