Meddane
The "Fresh Install with Data Import (V2V)" feature is an alternative method for DRS Disaster Recovery System. Basically the DRS allows the admin to take a backup of a Cisco Unity Connection node. The DRS backup is useful when you want to rebuild a new publisher because hardware issues or system corruption. In this case you need to install a new publisher with the same version, network settings and Security Password, then perform the DRS restore action to copy the DRS backup of the old publisher.
In some scenario, the DRS has limitations and cannot be used to restore the old configuration, for instance you have an existing cisco Unity Connection cluster version 12.5 installed in a specific Cisco UCS ESXi and you want to upgrade to version 15 but the new cluster should be installed in a new Cisco UCS hardware or a new Environment ESXi. In this case the DRS mechanism cannot be used because it requires the same version to restore the backup.
The "Fresh Install with Data Import" is the alternative when you want to upgrade to another version and you need to change the infrastructure hardware. The "Fresh Install with Data Import" feature export the configuration data from the old node to a remote SFTP server and later you import it into the new node.
In this scenario, I have a Unity Connection publisher with version 12.5 and the goal is to upgrade to version 14 without losing the configuration data.
First install the COP file ciscocm.cuc_DataExport_v1.1.k4.cop.sha512 in the old node using SFTP. This COP file enables the “utils system upgrade dataexport initiate” command in Unity Connection for migrations to 15.
“ciscocm.cuc_DataExport_v1.1.k4.cop.sha512” is applicable only for versions 11.5, 12.0, and up to 12.5SU5.
SSH to the old node and export the source configuration's data to SFTP server using the utils system upgrade dataexport initiate command, the command output will invite you to enter the directory path, IP address, the username/password of the SFTP server.
Install the new node with version 15 and when you are prompted with Platform Installation Wizard, select the "Import" option.
Later the wizard will display a windows to locate and import the configuration data you exported previously. Enter the SFTP informations and the correct directory path as shown below and continue the installation and you get a new node with version 15 and the old configuration data.
12 Comments
etmarcof
Level 3
Level 3
Hi @Meddane ,
In your post you say that "This COP file enables the “utils system upgrade dataexport initiate” command in Unity Connection 10.c, 11.x and 12.x for migrations to 15."  Where do you saw this information?
In readme of cop file ciscocm.cuc_DataExport_v1.1.k4.cop.sha512 i it's says that  This cop is installable for source releases 11.5.x, 12.0.x to pre 12.5SU5 and 14FCS.
Tried to install from version 11.0:
10/28/2024 07:29:07 Validating version compatability.
10/28/2024 07:29:07 Current active version is 11.0.1.22900-14
10/28/2024 07:29:07 This COP file is applicable only to Cisco Unity Connection 11.5.x to pre 12.5.1SU5 and 14FCS Releases. The version deployed on the server is (11.0.1.22900-14).
***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR ***** ERROR *****
[24/10/28_07:29:07] locale_install.sh: Not running installdb.
[24/10/28_07:29:07] locale_install.sh: Successful running of copstart for ciscocm.cuc_DataExport_v1.1.k4.cop
Successfully installed ciscocm.cuc_DataExport_v1.1.k4.cop.sha512
Locale ciscocm.cuc_DataExport_v1.1.k4.cop has been installed successfully. A reboot is not necessary for the changes to take effect.
I would like to know if  i try to run data export if will work ?
Best Regard,
The COP “ciscocm.cuc_DataExport_v1.1.k4.cop.sha512” is applicable only for versions 11.5, 12.0, and up to 12.5SU5. @Meddane , you must update your blog.
Meddane
@etmarcof  @Nithin Eluvathingal  Done, don't worry.
eljose_lol
Hello @Meddane
Can i use the same hostname and ip address during the CLI export process?
UCRY16
During data export from Unity connection does users loose access to voicemails?
Saw below notes from Cisco and am concerned. Did anyone noticed this?
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/15/install_upgrade/guide/b_15cuciumg/b_15cuciumg_chapter_00.html#Cisco_Concept.dita_27807633-1aea-4e05-be92-fe88ae6bc66a
  • It is recommended to execute this CLI during Off hours to avoid voicemail impact. While CLI execution is in progress, you will not be able to access voicemails and send messages.
  • It will continue to run in background in case of any network disconnect.
Sinu
The exported data include all the voice mails, recorded prompts etc ?
@Sinu ,AFAIK it includes the voicemail and prompts.
@eljose_lol you can use the Same IP and Hostname.
yehuda-cohen
Hi Everyone ,
I tried to install a new Unity in 15 SU3 version after making an export on current Unity with 12.5.1 SU3 , and getting an error message .
there is no problem with the Sftp , what should be the problem ?
Best Regards ,
Yehuda
loizosko
anybody figured ?
getting exact same issue. does not seem to be hitting my sftp server. i verified is working fine and note is online . can be pinged from network
Re-export the data and try again.
Ensure the destination host name and IP address match those configured for the new server build.
loizosko
i want to update everybody that must be something with the 15 su3 file.
i did exactly the same procedure on same esx host etc with 14 su4 and worked fine.
i also had a tac case and in the install logs said something about the esx did not have ntp servers. (it was true the first time) but then i added and tried multiple times with no success.
the 14 su4 worked fine. so from that as freshly installed i should be able to upgrade to 15su3
