Engin Zeren
Here is the step :
su - oracle
dbadm -C db
Number of tables to be checked: 195
Number of tables checked OK:    195
Number of tables out-of-sync:   0
If there were out-of-sync tables then the prosecure to fix it:
1- Login to EMS side that has bad data :
su - oracle
dbadm -A copy -o <OWNER> -t <TABEL NAME>
2- Let's say the out-of-sync table is subscriber_feature_data. Then command should be :
dbadm –A copy –o opticall –t subscriber_feature_data
3- To check replication status :
su - oracle
dbadm –C rep
OPTICAL2::Deftrandest is empty?           YES
OPTICAL2::dba_repcatlog is empty?       YES
OPTICAL2::Deferror is empty?              YES ßMake sure it is “YES”
OPTICAL2::Deftran is empty?                  YES
OPTICAL2::Has no broken job?               YES
OPTICAL2::JQ Lock is empty?                YES
OPTICAL1::Deftrandest is empty?          YES
OPTICAL1::dba_repcatlog is empty?      YES
OPTICAL1::Deferror is empty?             YES ßMake sure it is “YES”
OPTICAL1::Deftran is empty?                YES
OPTICAL1::Has no broken job?              YES
OPTICAL1::JQ Lock is empty?               YES
If "DeferroR is emty?" value is NO then follow this steps:
1-
ssh root@EMS-B
su - oracle
dbadm -A truncate_defferor
2-
ssh root@EMS-A
su - oracle
3- Verify again with dbadm -C rep that problem has been resolved.
