cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: JIN HO LEE on 04-12-2010 02:14:55 PM
hi
I have to prepare the demostration about cvp. because my biggest customer want to deploy cvp.
but I have one problem for demo. this is like under.
I setup the Courtesy Callback on cvp & vg & icm.
I got error message from cvp. the log file was attached.
you can found out error on activity_log2010-12-03-22-17-54.txt
Validate_01 element's values are null and return error.
and  Element_entry log is writed twice.
10.10.20.20.1291382274171.37.CallbackEntry,12/03/2010 22:17:54.421,Validate_01,enter,
22:17:54.421,Validate_01,custom,Callback_Validate,ELEMENT_ENTRY
22:17:54.437,Validate_01,custom,Callback_Validate,ELEMENT_ENTRY
10.10.20.20.1291382274171.37.CallbackEntry,12/03/2010 22:17:54.437,Validate_01,exit,error
How do I fix the problem?
thank you.
Subject: RE: Can't get values from Validate_01 element on Courtesy Callback
Replied by: Jeffrey Kulacz on 07-12-2010 09:14:12 PM
Is is possible for you to post a screenshot of your ICM script ?
Thanks.
fabien_damien
Hello Jin,
Any luck with that issue?
Thanks.
