Carl Duvall
I finally found some online help from others suggesting a formula for calculating the start/end/duration time of calls (sorry, I don't have the sources).  I've incorporated these into an excel macro for exported CDR information.  Not only does this calculate the duration, but it also converts it into seconds/mins/hours based on the amount of time involved.  Hopefully you will find this useful.
***NOTE*** - The selection part may not cover all of your records, but it goes well over 200k rows.  Anymore than that and you'll need to paste the formula to the end.  Also, this utilizes the Eastern timezone.
I'll leave this open for editing if someone can imporve the macro, more power to you.  I'm a network guy, not a scripter by nature.
Cheers,
Carl
Sub CDRFull()
' CDRFull Macro
    Columns("AW:AW").Select
    Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
    Columns("AY:AY").Select
    Range("AW1").Select
    ActiveCell.FormulaR1C1 = "Connect Time"
    Range("AY1").Select
    ActiveCell.FormulaR1C1 = "Disconnect Time"
    Range("AZ1").Select
    ActiveCell.FormulaR1C1 = "Duration"
    Range("AW2").Select
    ActiveCell.FormulaR1C1 = "=(((RC[-1]-(5*3600))/86400)+25569)"
    Range("AW2").Select
    Selection.Copy
    Range("AW3").Select
    ActiveWindow.ScrollRow = 319
    ActiveWindow.ScrollRow = 637
    ActiveWindow.ScrollRow = 1592
    ActiveWindow.ScrollRow = 2228
    ActiveWindow.ScrollRow = 2546
    ActiveWindow.ScrollRow = 2864
    ActiveWindow.ScrollRow = 3819
    ActiveWindow.ScrollRow = 4455
    ActiveWindow.ScrollRow = 4773
    ActiveWindow.ScrollRow = 5728
    ActiveWindow.ScrollRow = 6046
    ActiveWindow.ScrollRow = 6682
    ActiveWindow.ScrollRow = 7001
    ActiveWindow.ScrollRow = 7955
    ActiveWindow.ScrollRow = 8591
    ActiveWindow.ScrollRow = 8909
    ActiveWindow.ScrollRow = 9546
    ActiveWindow.ScrollRow = 10500
    ActiveWindow.ScrollRow = 12409
    ActiveWindow.ScrollRow = 13046
    ActiveWindow.ScrollRow = 13682
    ActiveWindow.ScrollRow = 14000
    ActiveWindow.ScrollRow = 15273
    ActiveWindow.ScrollRow = 15909
    ActiveWindow.ScrollRow = 16863
    ActiveWindow.ScrollRow = 17182
    ActiveWindow.ScrollRow = 17818
    ActiveWindow.ScrollRow = 19091
    ActiveWindow.ScrollRow = 20045
    ActiveWindow.ScrollRow = 20681
    ActiveWindow.ScrollRow = 21954
    ActiveWindow.ScrollRow = 22272
    ActiveWindow.ScrollRow = 22908
    ActiveWindow.ScrollRow = 23863
    ActiveWindow.ScrollRow = 25136
    ActiveWindow.ScrollRow = 26090
    ActiveWindow.ScrollRow = 27045
    ActiveWindow.ScrollRow = 27363
    ActiveWindow.ScrollRow = 29272
    ActiveWindow.ScrollRow = 30226
    ActiveWindow.ScrollRow = 31181
    ActiveWindow.ScrollRow = 32135
    ActiveWindow.ScrollRow = 33090
    ActiveWindow.ScrollRow = 34362
    ActiveWindow.ScrollRow = 34999
    ActiveWindow.ScrollRow = 35635
    ActiveWindow.ScrollRow = 36271
    ActiveWindow.ScrollRow = 37544
    ActiveWindow.ScrollRow = 38180
    ActiveWindow.ScrollRow = 39453
    ActiveWindow.ScrollRow = 40407
    ActiveWindow.ScrollRow = 41680
    ActiveWindow.ScrollRow = 42634
    ActiveWindow.ScrollRow = 44225
    ActiveWindow.ScrollRow = 46134
    ActiveWindow.ScrollRow = 46770
    ActiveWindow.ScrollRow = 49634
    ActiveWindow.ScrollRow = 51543
    ActiveWindow.ScrollRow = 53452
    ActiveWindow.ScrollRow = 55043
    ActiveWindow.ScrollRow = 56633
    ActiveWindow.ScrollRow = 57588
    ActiveWindow.ScrollRow = 59179
    ActiveWindow.ScrollRow = 61406
    ActiveWindow.ScrollRow = 62360
    ActiveWindow.ScrollRow = 63951
    ActiveWindow.ScrollRow = 64587
    ActiveWindow.ScrollRow = 66178
    ActiveWindow.ScrollRow = 68087
    ActiveWindow.ScrollRow = 70314
    ActiveWindow.ScrollRow = 72223
    ActiveWindow.ScrollRow = 75405
    ActiveWindow.ScrollRow = 77632
    ActiveWindow.ScrollRow = 80177
    ActiveWindow.ScrollRow = 82086
    ActiveWindow.ScrollRow = 83995
    ActiveWindow.ScrollRow = 84950
    ActiveWindow.ScrollRow = 86540
    ActiveWindow.ScrollRow = 87495
    ActiveWindow.ScrollRow = 89086
    ActiveWindow.ScrollRow = 89404
    ActiveWindow.ScrollRow = 90995
    ActiveWindow.ScrollRow = 92267
    ActiveWindow.ScrollRow = 93540
    ActiveWindow.ScrollRow = 94812
    ActiveWindow.ScrollRow = 95767
    ActiveWindow.ScrollRow = 97040
    ActiveWindow.ScrollRow = 98312
    ActiveWindow.ScrollRow = 99903
    ActiveWindow.ScrollRow = 101176
    ActiveWindow.ScrollRow = 103721
    ActiveWindow.ScrollRow = 104357
    ActiveWindow.ScrollRow = 105312
    ActiveWindow.ScrollRow = 105630
    ActiveWindow.ScrollRow = 106584
    ActiveWindow.ScrollRow = 108175
    ActiveWindow.ScrollRow = 109448
    ActiveWindow.ScrollRow = 110402
    ActiveWindow.ScrollRow = 112311
    ActiveWindow.ScrollRow = 113266
    ActiveWindow.ScrollRow = 115175
    ActiveWindow.ScrollRow = 117084
    ActiveWindow.ScrollRow = 120583
    ActiveWindow.ScrollRow = 121856
    ActiveWindow.ScrollRow = 124083
    ActiveWindow.ScrollRow = 125674
    ActiveWindow.ScrollRow = 127583
    ActiveWindow.ScrollRow = 129174
    ActiveWindow.ScrollRow = 130446
    ActiveWindow.ScrollRow = 131719
    ActiveWindow.ScrollRow = 132992
    ActiveWindow.ScrollRow = 136491
    ActiveWindow.ScrollRow = 138718
    ActiveWindow.ScrollRow = 139673
    ActiveWindow.ScrollRow = 141582
    ActiveWindow.ScrollRow = 143491
    ActiveWindow.ScrollRow = 144764
    ActiveWindow.ScrollRow = 146036
    ActiveWindow.ScrollRow = 147309
    ActiveWindow.ScrollRow = 148263
    ActiveWindow.ScrollRow = 149854
    ActiveWindow.ScrollRow = 151445
    ActiveWindow.ScrollRow = 153036
    ActiveWindow.ScrollRow = 153990
    ActiveWindow.ScrollRow = 154626
    ActiveWindow.ScrollRow = 155899
    ActiveWindow.ScrollRow = 156854
    ActiveWindow.ScrollRow = 158126
    ActiveWindow.ScrollRow = 159081
    ActiveWindow.ScrollRow = 160353
    ActiveWindow.ScrollRow = 160990
    ActiveWindow.ScrollRow = 161944
    ActiveWindow.ScrollRow = 162899
    ActiveWindow.ScrollRow = 164171
    ActiveWindow.ScrollRow = 165126
    ActiveWindow.ScrollRow = 165444
    ActiveWindow.ScrollRow = 166398
    ActiveWindow.ScrollRow = 167353
    ActiveWindow.ScrollRow = 167989
    ActiveWindow.ScrollRow = 169262
    ActiveWindow.ScrollRow = 170216
    ActiveWindow.ScrollRow = 171171
    ActiveWindow.ScrollRow = 172125
    ActiveWindow.ScrollRow = 173716
    ActiveWindow.ScrollRow = 174352
    ActiveWindow.ScrollRow = 175943
    ActiveWindow.ScrollRow = 176898
    ActiveWindow.ScrollRow = 178170
    ActiveWindow.ScrollRow = 179443
    ActiveWindow.ScrollRow = 180079
    ActiveWindow.ScrollRow = 180716
    ActiveWindow.ScrollRow = 181670
    ActiveWindow.ScrollRow = 182306
    ActiveWindow.ScrollRow = 182943
    ActiveWindow.ScrollRow = 183897
    ActiveWindow.ScrollRow = 184533
    ActiveWindow.ScrollRow = 184852
    ActiveWindow.ScrollRow = 185488
    ActiveWindow.ScrollRow = 186442
    ActiveWindow.ScrollRow = 187079
    ActiveWindow.ScrollRow = 188351
    ActiveWindow.ScrollRow = 188988
    ActiveWindow.ScrollRow = 189942
    ActiveWindow.ScrollRow = 190897
    ActiveWindow.ScrollRow = 191533
    ActiveWindow.ScrollRow = 192169
    ActiveWindow.ScrollRow = 193442
    ActiveWindow.ScrollRow = 194078
    ActiveWindow.ScrollRow = 194396
    ActiveWindow.ScrollRow = 195351
    ActiveWindow.ScrollRow = 195669
    ActiveWindow.ScrollRow = 195987
    ActiveWindow.ScrollRow = 196942
    ActiveWindow.ScrollRow = 197578
    ActiveWindow.ScrollRow = 198214
    ActiveWindow.ScrollRow = 198851
    ActiveWindow.ScrollRow = 199805
    ActiveWindow.ScrollRow = 200441
    ActiveWindow.ScrollRow = 200760
    ActiveWindow.ScrollRow = 201078
    ActiveWindow.ScrollRow = 202032
    ActiveWindow.ScrollRow = 202350
    ActiveWindow.ScrollRow = 202669
    ActiveWindow.ScrollRow = 202987
    ActiveWindow.ScrollRow = 203305
    ActiveWindow.ScrollRow = 203623
    ActiveWindow.ScrollRow = 204577
    ActiveWindow.ScrollRow = 205214
    ActiveWindow.ScrollRow = 205850
    ActiveWindow.ScrollRow = 207123
    ActiveWindow.ScrollRow = 207441
    ActiveWindow.ScrollRow = 207759
    ActiveWindow.ScrollRow = 208714
    ActiveWindow.ScrollRow = 209032
    ActiveWindow.ScrollRow = 209350
    ActiveWindow.ScrollRow = 210304
    ActiveWindow.ScrollRow = 210941
    ActiveWindow.ScrollRow = 211577
    ActiveWindow.ScrollRow = 211895
    ActiveWindow.ScrollRow = 212531
    ActiveWindow.ScrollRow = 213486
    ActiveWindow.ScrollRow = 213804
    ActiveWindow.ScrollRow = 214440
    ActiveWindow.ScrollRow = 215395
    ActiveWindow.ScrollRow = 216031
    ActiveWindow.ScrollRow = 216668
    ActiveWindow.ScrollRow = 217940
    ActiveWindow.ScrollRow = 218258
    ActiveWindow.ScrollRow = 218576
    ActiveWindow.ScrollRow = 219213
    ActiveWindow.ScrollRow = 219849
    ActiveWindow.ScrollRow = 220167
    ActiveWindow.ScrollRow = 220485
    ActiveWindow.ScrollRow = 221122
    ActiveWindow.ScrollRow = 221440
    ActiveWindow.ScrollRow = 222713
    ActiveWindow.ScrollRow = 223031
    ActiveWindow.ScrollRow = 223349
    ActiveWindow.ScrollRow = 224303
    ActiveWindow.ScrollRow = 224621
    ActiveWindow.ScrollRow = 225576
    ActiveWindow.ScrollRow = 225894
    ActiveWindow.ScrollRow = 226530
    ActiveWindow.ScrollRow = 226849
    ActiveWindow.ScrollRow = 227485
    ActiveWindow.ScrollRow = 228121
    ActiveWindow.ScrollRow = 229076
    ActiveWindow.ScrollRow = 229394
    ActiveWindow.ScrollRow = 229712
    ActiveWindow.ScrollRow = 230030
    ActiveWindow.ScrollRow = 230348
    ActiveWindow.ScrollRow = 230985
    ActiveWindow.ScrollRow = 231303
    ActiveWindow.ScrollRow = 231621
    Range("AW3:AW231658").Select
    ActiveSheet.Paste
    Range("AW3:AW231658,AW2").Select
    Range("AW2").Activate
    Application.CutCopyMode = False
    Selection.NumberFormat = "[$-409]m/d/yy h:mm AM/PM;@"
    Range("AY2").Select
    Range("AY2").Select
    Selection.Copy
    Range("AY3").Select
    ActiveWindow.ScrollRow = 8273
    ActiveWindow.ScrollRow = 9228
    ActiveWindow.ScrollRow = 14954
    ActiveWindow.ScrollRow = 16545
    ActiveWindow.ScrollRow = 24817
    ActiveWindow.ScrollRow = 25772
    ActiveWindow.ScrollRow = 27681
    ActiveWindow.ScrollRow = 29590
    ActiveWindow.ScrollRow = 31499
    ActiveWindow.ScrollRow = 33726
    ActiveWindow.ScrollRow = 37862
    ActiveWindow.ScrollRow = 40089
    ActiveWindow.ScrollRow = 43271
    ActiveWindow.ScrollRow = 45816
    ActiveWindow.ScrollRow = 48679
    ActiveWindow.ScrollRow = 54724
    ActiveWindow.ScrollRow = 60769
    ActiveWindow.ScrollRow = 63315
    ActiveWindow.ScrollRow = 67769
    ActiveWindow.ScrollRow = 69996
    ActiveWindow.ScrollRow = 73178
    ActiveWindow.ScrollRow = 79859
    ActiveWindow.ScrollRow = 85904
    ActiveWindow.ScrollRow = 90040
    ActiveWindow.ScrollRow = 94176
    ActiveWindow.ScrollRow = 97994
    ActiveWindow.ScrollRow = 100539
    ActiveWindow.ScrollRow = 104675
    ActiveWindow.ScrollRow = 108811
    ActiveWindow.ScrollRow = 111039
    ActiveWindow.ScrollRow = 112948
    ActiveWindow.ScrollRow = 115811
    ActiveWindow.ScrollRow = 119311
    ActiveWindow.ScrollRow = 121538
    ActiveWindow.ScrollRow = 126628
    ActiveWindow.ScrollRow = 129492
    ActiveWindow.ScrollRow = 130764
    ActiveWindow.ScrollRow = 132673
    ActiveWindow.ScrollRow = 134264
    ActiveWindow.ScrollRow = 136173
    ActiveWindow.ScrollRow = 141900
    ActiveWindow.ScrollRow = 146354
    ActiveWindow.ScrollRow = 148581
    ActiveWindow.ScrollRow = 150490
    ActiveWindow.ScrollRow = 151763
    ActiveWindow.ScrollRow = 153672
    ActiveWindow.ScrollRow = 155581
    ActiveWindow.ScrollRow = 157172
    ActiveWindow.ScrollRow = 158444
    ActiveWindow.ScrollRow = 161626
    ActiveWindow.ScrollRow = 164489
    ActiveWindow.ScrollRow = 167035
    ActiveWindow.ScrollRow = 168625
    ActiveWindow.ScrollRow = 169580
    ActiveWindow.ScrollRow = 172443
    ActiveWindow.ScrollRow = 173398
    ActiveWindow.ScrollRow = 174989
    ActiveWindow.ScrollRow = 176579
    ActiveWindow.ScrollRow = 181988
    ActiveWindow.ScrollRow = 188033
    ActiveWindow.ScrollRow = 189306
    ActiveWindow.ScrollRow = 190260
    ActiveWindow.ScrollRow = 190578
    ActiveWindow.ScrollRow = 191215
    ActiveWindow.ScrollRow = 192487
    ActiveWindow.ScrollRow = 194715
    ActiveWindow.ScrollRow = 201714
    ActiveWindow.ScrollRow = 205532
    ActiveWindow.ScrollRow = 206486
    ActiveWindow.ScrollRow = 208395
    ActiveWindow.ScrollRow = 210622
    ActiveWindow.ScrollRow = 215713
    ActiveWindow.ScrollRow = 217304
    ActiveWindow.ScrollRow = 218895
    ActiveWindow.ScrollRow = 222076
    ActiveWindow.ScrollRow = 223985
    ActiveWindow.ScrollRow = 227803
    ActiveWindow.ScrollRow = 230667
    Range("AY3:AY231658").Select
    ActiveSheet.Paste
    Range("AY3:AY231658,AY2").Select
    Range("AY2").Activate
    Range("AZ2").Select
    ActiveCell.FormulaR1C1 = _
        "=IF(RC[-4]=0,0&"" secs"",IF(RC[-2]-RC[-4]>=3600,ROUND(((RC[-2]-RC[-4])/3600),2)&"" hrs"",IF(RC[-2]-RC[-4]>=60,ROUND(((RC[-2]-RC[-4])/60),2)&"" mins"",RC[-2]-RC[-4]&"" secs"")))"
    Range("AZ2").Select
    Selection.Copy
    Range("AZ3").Select
    ActiveWindow.ScrollRow = 3501
    ActiveWindow.ScrollRow = 5092
    ActiveWindow.ScrollRow = 6364
    ActiveWindow.ScrollRow = 11137
    ActiveWindow.ScrollRow = 14318
    ActiveWindow.ScrollRow = 15591
    ActiveWindow.ScrollRow = 19409
    ActiveWindow.ScrollRow = 30862
    ActiveWindow.ScrollRow = 31817
    ActiveWindow.ScrollRow = 36907
    ActiveWindow.ScrollRow = 39135
    ActiveWindow.ScrollRow = 45498
    ActiveWindow.ScrollRow = 50588
    ActiveWindow.ScrollRow = 55997
    ActiveWindow.ScrollRow = 64269
    ActiveWindow.ScrollRow = 72859
    ActiveWindow.ScrollRow = 78586
    ActiveWindow.ScrollRow = 81132
    ActiveWindow.ScrollRow = 83677
    ActiveWindow.ScrollRow = 85586
    ActiveWindow.ScrollRow = 91631
    ActiveWindow.ScrollRow = 99267
    ActiveWindow.ScrollRow = 102766
    ActiveWindow.ScrollRow = 107539
    ActiveWindow.ScrollRow = 110084
    ActiveWindow.ScrollRow = 113584
    ActiveWindow.ScrollRow = 116447
    ActiveWindow.ScrollRow = 118674
    ActiveWindow.ScrollRow = 122492
    ActiveWindow.ScrollRow = 125356
    ActiveWindow.ScrollRow = 133310
    ActiveWindow.ScrollRow = 135855
    ActiveWindow.ScrollRow = 137128
    ActiveWindow.ScrollRow = 137764
    ActiveWindow.ScrollRow = 139037
    ActiveWindow.ScrollRow = 139991
    ActiveWindow.ScrollRow = 140627
    ActiveWindow.ScrollRow = 142218
    ActiveWindow.ScrollRow = 144127
    ActiveWindow.ScrollRow = 145082
    ActiveWindow.ScrollRow = 146991
    ActiveWindow.ScrollRow = 149536
    ActiveWindow.ScrollRow = 150809
    ActiveWindow.ScrollRow = 152399
    ActiveWindow.ScrollRow = 157808
    ActiveWindow.ScrollRow = 159717
    ActiveWindow.ScrollRow = 161308
    ActiveWindow.ScrollRow = 163535
    ActiveWindow.ScrollRow = 166080
    ActiveWindow.ScrollRow = 167671
    ActiveWindow.ScrollRow = 168307
    ActiveWindow.ScrollRow = 170534
    ActiveWindow.ScrollRow = 176261
    ActiveWindow.ScrollRow = 177216
    ActiveWindow.ScrollRow = 181034
    ActiveWindow.ScrollRow = 182624
    ActiveWindow.ScrollRow = 183261
    ActiveWindow.ScrollRow = 185806
    ActiveWindow.ScrollRow = 187715
    ActiveWindow.ScrollRow = 193124
    ActiveWindow.ScrollRow = 195033
    ActiveWindow.ScrollRow = 197896
    ActiveWindow.ScrollRow = 199169
    ActiveWindow.ScrollRow = 203941
    ActiveWindow.ScrollRow = 206805
    ActiveWindow.ScrollRow = 208077
    ActiveWindow.ScrollRow = 209668
    ActiveWindow.ScrollRow = 209986
    ActiveWindow.ScrollRow = 211259
    ActiveWindow.ScrollRow = 213168
    ActiveWindow.ScrollRow = 214122
    ActiveWindow.ScrollRow = 214759
    ActiveWindow.ScrollRow = 215077
    ActiveWindow.ScrollRow = 216349
    ActiveWindow.ScrollRow = 216986
    ActiveWindow.ScrollRow = 217622
    ActiveWindow.ScrollRow = 219531
    ActiveWindow.ScrollRow = 220804
    ActiveWindow.ScrollRow = 221758
    ActiveWindow.ScrollRow = 222394
    ActiveWindow.ScrollRow = 223667
    ActiveWindow.ScrollRow = 225258
    ActiveWindow.ScrollRow = 226212
    ActiveWindow.ScrollRow = 227167
    ActiveWindow.ScrollRow = 228439
    ActiveWindow.ScrollRow = 228758
    ActiveWindow.SmallScroll Down:=10
    Range("AZ3:AZ231658").Select
    ActiveSheet.Paste
    ActiveWindow.ScrollColumn = 51
    ActiveWindow.ScrollColumn = 50
    ActiveWindow.ScrollColumn = 49
    ActiveWindow.ScrollColumn = 48
    ActiveWindow.ScrollColumn = 47
    ActiveWindow.ScrollColumn = 46
    ActiveWindow.ScrollColumn = 45
    ActiveWindow.ScrollColumn = 44
    ActiveWindow.SmallScroll Down:=-70
End Sub
