01-10-2013 06:52 AM - edited 03-12-2019 09:56 AM
<DIV style="POSITION: absolute; WIDTH: 1px; HEIGHT: 1px; OVERFLOW: hidden; TOP: 0px; LEFT: -10000px" id=_mcePaste class=mcePaste mcestyle="position: absolute; width: 1px; height: 1px; overflow: hidden; top: 0px; left: -10000px;"><BR mcebogus="1">
<IMG class="jive_macro jive_macro_toc" src="https://supportforums.cisco.com/4.5.4/images/tiny_mce3/plugins/jiveemoticons/images/spacer.gif" width=1 height=1 mce_src="/4.5.4/images/tiny_mce3/plugins/jiveemoticons/images/spacer.gif" jivemacro="toc" mcesrc="/4.5.4/images/tiny_mce3/plugins/jiveemoticons/images/spacer.gif">
<SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">Introduction</SPAN></A> </H1>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">I have over the years heard of cisco dsps using MIPs/credits but I never quite understood how they work. What I know like many of you is that I can tell how many number of channels a dsp can support based on the PVDM part number.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">e.g PVDM2-32 can support 32 channels; PVDM3-64 can support 64 channels and so on. In actual fact these computations depends largely on the dsp complexity mode.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">e.g A PVDM2-32 can support 32 channels or 32 G711 calls, using the default flex dsp mode. If the dsp complexity is changed to high, these values are significantly altered. <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Example: A PVDM2-32 that supports 32 channels in flex mode, will only support 16 channels in when the dsp complexity is changed to high. Mysteries abound in cisco world! Our job often times is to solve these riddles.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">So what is the magic behind all this mathematics? I hope you like maths! We will be doing a lot of it here! I have always wanted to know how these computations work and in here I attempt to share my findings.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">You may want to ask why bother knowing these details when we have the cisco dsp calculator. Here are my thoughts on this</SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"></SPAN></SPAN></SPAN> </P>
<P class="MsoListParagraphCxSpFirst" mcestyle="text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l2 level1 lfo2;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">It’s similar to asking why do you need to know SQL to query/update CUCM database when we already have the CUCM admin page to do that. The answer is obvious; something’s can’t be done from the ccm admin page.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l2 level1 lfo2;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">From a design point dsp calculator is very effective and should be used, however when things break then this direct knowledge becomes essential<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l2 level1 lfo2;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">As far as I know, the dsp calculator does not take into consideration dsp pooling. Hence you could end up with an over the size resources or “not so cost effective solution” when you could have used existing resources. <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpLast" mcestyle="margin: 0cm 0cm 10pt 36pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">DSP CREDITS</SPAN></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></H1>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Before we begin, it’s important to establish this fact. Each PVDM is equipped with a number of DSPs or cores. The higher the number of DSP, the greater the processing power of that PVDM. That obviously is not rocket science. But what is is this: Each dsp/cores within a Cisco PVDM is allocated a fixed amount of what is called “credits”. This is the “biggy!” The power of a DSP depends on the amount of credit that is allocated to it.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3 and PVDM2 DSP modules use a credit-based system. Each module is assigned a fixed number of "credits" that represent a measure of its capacity to process media streams. Each media operation, such as voice termination, transcoding, and so forth, is assigned a cost in terms of credits. As DSP resources are allocated for a media processing function, its cost value is subtracted from the available credits. A DSP module runs out of capacity when the available credits run out and are no longer sufficient for the requested operation<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">The table below shows the relations between PVDM, DSP and Credits allocated to each dsp
<TABLE style="BORDER-BOTTOM: medium none; BORDER-LEFT: medium none; MARGIN: auto auto auto -8.8pt; WIDTH: 489.1pt; BORDER-COLLAPSE: collapse; BORDER-TOP: medium none; BORDER-RIGHT: medium none; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt" class=MsoTableGrid border=1 cellSpacing=0 cellPadding=0 width=652 mcestyle="margin: auto auto auto -8.8pt; width: 489.1pt; border-collapse: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt;">
<TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes" mcestyle="mso-yfti-irow: 0; mso-yfti-firstrow: yes;">
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 162.8pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt" vAlign=top width=217 mcestyle="padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 162.8pt; padding-right: 5.4pt; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; border: windowtext 1pt solid;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 154.05pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=205 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 154.05pt; padding-right: 5.4pt; border-top: windowtext 1pt solid; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Number of DSP<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 172.25pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=230 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 172.25pt; padding-right: 5.4pt; border-top: windowtext 1pt solid; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Credits/DSP or Credits/Core<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 1" mcestyle="mso-yfti-irow: 1;">
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 162.8pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=217 mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 162.8pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-16<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 154.05pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=205 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 154.05pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">1<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 172.25pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=230 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 172.25pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">240<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 2" mcestyle="mso-yfti-irow: 2;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-32<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">480<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 3" mcestyle="mso-yfti-irow: 3;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-64<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">2<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TR style="mso-yfti-irow: 4" mcestyle="mso-yfti-irow: 4;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-128<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">3<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TR style="mso-yfti-irow: 5" mcestyle="mso-yfti-irow: 5;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-192<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">5<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">480,645 (read PVDM3-192 section)<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 6" mcestyle="mso-yfti-irow: 6;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM3-256<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">6<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">645<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 7" mcestyle="mso-yfti-irow: 7;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM2-8<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">1/2<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">120<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 8" mcestyle="mso-yfti-irow: 8;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM2-16<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TR style="mso-yfti-irow: 9" mcestyle="mso-yfti-irow: 9;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM2-32<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TR style="mso-yfti-irow: 10" mcestyle="mso-yfti-irow: 10;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM2-48<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TR style="mso-yfti-irow: 11; mso-yfti-lastrow: yes" mcestyle="mso-yfti-irow: 11; mso-yfti-lastrow: yes;">
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">PVDM2-64<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">4<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">240<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR></TBODY></TABLE></P>
<H2 style="LINE-HEIGHT: normal; MARGIN: 10pt 0cm 0pt" mcestyle="line-height: normal; margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">How to Determine Credits Allocated to A DSP</SPAN></A><o:p></o:p></H2>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PVDM3-Credits</SPAN></A><o:p></o:p></H2>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">The obvious question is this, how do we know the allocated Credit to a particular DSP. This is very important as you can see that the allocated credit to each DSP vary depending on what PVDM it is on. The answer is in two folds<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">1. The popular and most useful command showing dsp related information<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">“Show voice dsp group all”<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Please refer to this document to understand the output of this command in detail.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">https://supportforums.cisco.com/docs/DOC-29151<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">LABUK-02S-ERT01#Show voice dsp group all (for a PVDM3-128)<o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt; tab-stops: list 108.0pt; mso-list: l4 level3 lfo1;"><SPAN style="FONT-FAMILY: Wingdings; COLOR: #333333; FONT-SIZE: 10pt; mso-fareast-font-family: Wingdings; mso-bidi-font-family: Wingdings; mso-fareast-language: EN-GB; mso-ansi-language: EN; mso-bidi-font-size: 9.0pt" lang=EN mcestyle="font-family: Wingdings; color: #333333; font-size: 10pt; mso-fareast-font-family: Wingdings; mso-bidi-font-family: Wingdings; mso-fareast-language: EN-GB; mso-ansi-language: EN; mso-bidi-font-size: 9.0pt;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;">§<SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">DSP groups on slot 0:
dsp 1:
State: UP, firmware: 28.3.3
Max signal/voice channel: 43/43
<B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">Max credits: 645
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Transcoding channels allocated: 6<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Group: FLEX_GROUP_VOICE, complexity: FLEX
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Signaling channels allocated: 30
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"><o:p> </o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">dsp 2:
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Transcoding channels allocated: 14<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">dsp 3:<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> State: UP, firmware: 28.3.3<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> <SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="BORDER-BOTTOM: windowtext 1pt; BORDER-LEFT: windowtext 1pt; PADDING-BOTTOM: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 1pt; BORDER-RIGHT: windowtext 1pt; PADDING-TOP: 0cm; mso-border-alt: none windowtext 0cm" mcestyle="mso-border-alt: none windowtext 0cm; border: windowtext 1pt; padding: 0cm;">Max signal/voice channel: 42/43<o:p></o:p></SPAN></SPAN></B></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Max credits: 645</SPAN></SPAN></B><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">, Voice credits: 645, Video credits: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> num_of_sig_chnls_allocated: 18<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Transcoding channels allocated: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Group: FLEX_GROUP_VOICE, complexity: FLEX<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Shared credits: 276, reserved credits: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Signaling channels allocated: 18<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Voice channels allocated: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Credits used (rounded-up): 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Shared credits: 0, reserved credits: 369<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Codec: CONF_G729, maximum participants: 8<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Sessions per dsp: 7<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Slot: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Device idx: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> PVDM Slot: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Dsp Type: SP2600<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">From the output of the above command we can see that each core/dsp in a PVDM3-128 has a fixed credit of 645. This information is obtained from the <B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">“Max credits:645”</SPAN></B> Line<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">2. The second way is to use another not so popular command on the IOS: “show voice dsp capabilities slot x dsp y”, where x=PVDM slot and y=dsp number on PVDM<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">#show voice dsp capabilities slot 0 dsp 1 (PVDM3-128)<o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">DSP Type: SP2600 -43<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Card 0 DSP id 1 Capabilities:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>645</SPAN></B> ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>20,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>FC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>43,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>20,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Conference 8-party credits:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>40 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G729<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>92 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G722<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>92 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>ILBC<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>129<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">This command showed us the maximum credit for this dsp, which we can see is consistent with the output of the show voice dsp group all command.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Let’s look at another example: PVDM3-64<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="margin: 0cm 0cm 10pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">LABUK-01S-ERT01#show voice dsp group all<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">DSP groups on slot 0:<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 1:<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">Max credits: 480----
We see that 480 credit is allocated to each dsp in a PVDM3-64<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;">
<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 2:<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">Max credits: 480<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> <SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;">
<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Now we see that the credit on each dsp varies depending on the PVDM it resides in. <o:p></o:p></SPAN></SPAN></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PVDM2-Credits<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">On the PVDM2s, the credit allocated to each dsp in the PVDMs is 240 except for the PVDM2-8 which has 120 credits.<SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;">
<SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">#show voice dsp group all (PVDM2-64, showing only the first dsp)<SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 1: <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">State: UP, firmware: 4.4.20 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max signal/voice channel: 16/16 <B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max credits: 240 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Group: FLEX_GROUP_VOICE, complexity: FLEX <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Shared credits: 180, reserved credits: 0 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Signaling channels allocated: 16 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Voice channels allocated: 3 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Credits used: 60 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Voice channels: <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Ch02: voice port: 0/0/0:23.23, codec: g711ulaw, credits allocated: 30 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Ch03: voice port: 0/0/0:23.20, codec: g711ulaw, credits allocated: 15 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Ch04: voice port: 0/0/0:23.19, codec: g711ulaw, credits allocated: 15 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Group: FLEX_GROUP_XCODE, complexity: MEDIUM <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Shared credits: 0, reserved credits: 0 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Transcoding channels allocated: 0 <SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Credits used: 0<SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">THE PVDM3-192<SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The PVDM3-192 has a total of 5 dsps in it. In the table above you can see that the number of credits is 480,645. The reason for this is that this PVDM is built as follows:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM3-128 + PVDM3-64. <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">This PVDM is a combination of PVDM3-128 and PVDM3-64, hence since dsp of PVDM3-128 has 645 credits and each dsp of the PVDM3-64 has 480 credits<o:p></o:p></SPAN></SPAN></SPAN></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">DSP Channel Calculations/Voice Termination</SPAN></A><o:p></o:p></H1>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PVDM3</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Now that we understand and know how many credits each dsp has, we can then go on to attempt to understand how each dsp and corresponding PVDM support a “X” amount of voice channels.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The total amount of voice channels a dsp can support is dependent on two factors:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">1. Maximum Credits<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">2. DSP complexity mode.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">To understand more about DSP complexity mode, please refer to this document:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><A href="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1045532" mcehref="http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1045532"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #0000ff; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #0000ff; font-size: 12pt;">http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1045532</SPAN></A><o:p></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The amount of credit consumed by a single call or channel depends on the dsp complexity mode and on the dsp itself. The credits used for calls vary from DSP to DSP on the PVDM3. So question is how can we find out?<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The powerful command “show voice dsp capabilities” is the answer.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Example1 (DSP1 on a PVDM3-128)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">LABUK-01-ERT01#sh voice dsp capabilities slot 0 dsp 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">DSP Type: SP2600 -43<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Card 0 DSP id 1 Capabilities:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>645 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>20,</B><o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>FC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>43,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>20,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Conference 8-party credits:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;">G711<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>40 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G729<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>92 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G722<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>92 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>ILBC<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>129<o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Example2 (DSP1 on a PVDM3-64)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">LABUK-0115S-ERT01#sh voice dsp capabilities slot 0 dsp 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">DSP Type: SP2600 -32<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;">Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>480 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>34,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>22<o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>FC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>14,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Channel <SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>21,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>36 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G729<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>96 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G722<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>96 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>ILBC<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>120<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<TABLE style="BORDER-BOTTOM: medium none; BORDER-LEFT: medium none; BORDER-COLLAPSE: collapse; BORDER-TOP: medium none; BORDER-RIGHT: medium none; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt" class=MsoTableGrid border=1 cellSpacing=0 cellPadding=0 mcestyle="border-collapse: collapse; mso-border-alt: solid windowtext .5pt; mso-yfti-tbllook: 1184; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt;">
<TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes" mcestyle="mso-yfti-irow: 0; mso-yfti-firstrow: yes;">
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.5pt; padding-right: 5.4pt; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; border: windowtext 1pt solid;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.5pt; padding-right: 5.4pt; border-top: windowtext 1pt solid; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM3-16<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.55pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.55pt; padding-right: 5.4pt; border-top: windowtext 1pt solid; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM3-64<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM3-128<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 1" mcestyle="mso-yfti-irow: 1;">
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: windowtext 1pt solid; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="border-bottom: windowtext 1pt solid; border-left: windowtext 1pt solid; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.5pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">G711 credits<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.5pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.5pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">15<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<TD style="BORDER-BOTTOM: windowtext 1pt solid; BORDER-LEFT: #f0f0f0; PADDING-BOTTOM: 0cm; BACKGROUND-COLOR: transparent; PADDING-LEFT: 5.4pt; WIDTH: 115.55pt; PADDING-RIGHT: 5.4pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: windowtext 1pt solid; PADDING-TOP: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" vAlign=top width=154 mcestyle="border-bottom: windowtext 1pt solid; border-left: #f0f0f0; padding-bottom: 0cm; background-color: transparent; padding-left: 5.4pt; width: 115.55pt; padding-right: 5.4pt; border-top: #f0f0f0; border-right: windowtext 1pt solid; padding-top: 0cm; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">15<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 2" mcestyle="mso-yfti-irow: 2;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">HC Credits<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">24<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">34<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">32<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 3; mso-yfti-lastrow: yes" mcestyle="mso-yfti-irow: 3; mso-yfti-lastrow: yes;">
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">MC Credits<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">20<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">22<o:p></o:p></SPAN></SPAN></SPAN></P></TD>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal; margin: auto auto 0pt; mso-add-space: auto;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">20<o:p></o:p></SPAN></SPAN></SPAN></P></TD></TR></TBODY></TABLE></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PVDM2</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">NB: MIPS is the same as credits<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: 'Verdana','sans-serif'; FONT-SIZE: 10pt" mcestyle="font-family: 'Verdana','sans-serif'; font-size: 10pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">PVDM2-8 Signaling
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">-Each Pri slots also count for 1 channel<o:p></o:p></SPAN></SPAN></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">DSP Channel Allocation Example</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">So now that we have established these facts let’s look at an example.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">How many channels does a PVDM3-128 support in flex mode (uses G711 for analysis) and in High complexity mode (HC)<o:p></o:p></SPAN></SPAN></SPAN></P>
<H3 style="LINE-HEIGHT: normal; MARGIN: 10pt 0cm 0pt" mcestyle="line-height: normal; margin: 10pt 0cm 0pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 12pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 12pt;">Flex mode</SPAN></SPAN></SPAN></SPAN></A><SPAN style="FONT-FAMILY: ; COLOR: #4f81bd" mcestyle="color: #4f81bd;"><SPAN style="FONT-FAMILY: Cambria" mcestyle="font-family: Cambria;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="mso-bookmark: _Toc345594646" mcestyle="mso-bookmark: _Toc345594646;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-WEIGHT: normal; mso-bidi-font-weight: bold" mcestyle="font-weight: normal; mso-bidi-font-weight: bold;">:</SPAN></SPAN></SPAN><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-WEIGHT: normal; mso-bidi-font-weight: bold" mcestyle="font-weight: normal; mso-bidi-font-weight: bold;"> <o:p></o:p></SPAN></SPAN></SPAN></SPAN></SPAN></H3>
<P class="MsoNormal" mcestyle="line-height: 50%; margin: 0cm 0cm 10pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max credit/dsp =645. G711 credit =15, hence 645/15= 43.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">So each dsp will support 43 channels/voice calls. However we know that this PVDM has 3 dsps in it, hence if we multiply 43*3=129 channels. So that’s not right because it’s a PVDM3-128. The way this is then done is this.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Dsp1=43, dsp2=43, dsp3-42 channels, making a total of 128 channels.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">This is what we see from the output of the show voice dsp group all command for the dsp3<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">dsp 3:<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> State: UP, firmware: 28.3.3<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> <SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="BORDER-BOTTOM: windowtext 1pt; BORDER-LEFT: windowtext 1pt; PADDING-BOTTOM: 0cm; PADDING-LEFT: 0cm; PADDING-RIGHT: 0cm; BORDER-TOP: windowtext 1pt; BORDER-RIGHT: windowtext 1pt; PADDING-TOP: 0cm; mso-border-alt: none windowtext 0cm" mcestyle="mso-border-alt: none windowtext 0cm; border: windowtext 1pt; padding: 0cm;">Max signal/voice channel: 42/43----
Max signal=42 out of a possible 43<o:p></o:p></SPAN></SPAN></B></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Max credits: 645</SPAN></SPAN></B><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;">, Voice credits: 645, Video credits: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> num_of_sig_chnls_allocated: 18<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Transcoding channels allocated: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Group: FLEX_GROUP_VOICE, complexity: FLEX<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Shared credits: 276, reserved credits: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Signaling channels allocated: 18<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Voice channels allocated: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Credits used (rounded-up): 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Shared credits: 0, reserved credits: 369<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Codec: CONF_G729, maximum participants: 8<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Sessions per dsp: 7<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Slot: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Device idx: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 0pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> PVDM Slot: 0<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"> Dsp Type: SP2600<o:p></o:p></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><SPAN style="FONT-FAMILY: 'Arial','sans-serif'; COLOR: #333333; FONT-SIZE: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN" lang=EN mcestyle="font-family: 'Arial','sans-serif'; color: #333333; font-size: 9pt; mso-fareast-font-family: 'Times New Roman'; mso-fareast-language: EN-GB; mso-ansi-language: EN;"><o:p> </o:p></SPAN></P>
<H3 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 12pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 12pt;">High Complexity Mode: (HC)</SPAN></SPAN></A><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p></o:p></SPAN></H3>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max credit/dsp=645, HC credit=32, hence 645/32=20 (rounded off to the lowest number). Hence with dsp we will have 20*3=60 channels<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">So we see that a PVDM3-128 in HC will only support less than half this capacity if the dsp mode is changed to High.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The show voice dsp group all command shows exactly this:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">#sh voice dsp group all<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">DSP groups on slot 0:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 1:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>State: UP, firmware: 28.3.3<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;">Max signal/voice channel: 20/20----
Channels reduced to 20<o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max credits: 645, Voice credits: 645, Video credits: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>num_of_sig_chnls_allocated: 20<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Transcoding channels allocated: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_VOICE, complexity: HIGH------With HC mode<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 630, reserved credits: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Signaling channels allocated: 20<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Voice channels allocated: 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits used (rounded-up): 15<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Voice channels:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Ch01: voice port: 0/0/0:15.1, codec: g711ulaw, credits allocated: 15<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Slot: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Device idx: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>PVDM Slot: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Dsp Type: SP2600<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM2-16<o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Example 2: How many channels does a PVDM2-16 support in both flex and HC mode.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">for a PVDM2-16 DSP in Flex mode it will support 16 channels. Following from our calculations:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Each dsp=240 credit, G711 credt (flex mode)=15, 240/15=16<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">In HC mode, HC credit (e.g G729 codec)=30 credits, hence 240/30 = 8.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Hence we see that the channel capacity is halved.<o:p></o:p></SPAN></SPAN></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PRI Configuration, Analogue Voice port and DSP allocation</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">One of the most significant aspect of this is that you won’t be able to enable more voice ports that the total number of channels your dsp can support especially when the dsp complexity mode is anything other than flex. This is regardless of the actual codec you use on your voice calls. <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">E.g assuming we have a PVDM3-16 which has 20 credits. If we set our dsp complexity mode to high, we will only have 8 channels. Now if we use G711 on our calls, for 8 calls we will have a total of 8*15=120 credits. So we should have additional 120 credits left. But what you will discover is that you will only be able to configure only 8 pri time slots or 8 analogues voice ports. This is because the dsp capacity is calculated based on its configured dsp complexity mode not on the actual codec used for the call.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">E.g<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>State: UP, firmware: 26.8.1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max signal/voice channel: 43/43<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max credits: 645<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>num_of_sig_chnls_allocated: 43<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_VOICE, complexity: FLEX<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 624, reserved credits: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Signaling channels allocated: 43<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits used (rounded-up): 21<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Ch01: voice port: 0/0/1:15.1, codec: g729r8, credits allocated: 20 (in flex mode, g729 uses 20credits)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">A single g729 call in this codec complexity mode(HC) uses 33 credits<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max signal/voice channel: 20/20<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_VOICE, complexity: HIGH<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 612, reserved credits: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits used (rounded-up): 33<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Ch01: voice port: 0/0/0:15.1, codec: g729r8, credits allocated: 32<o:p></o:p></SPAN></SPAN></SPAN></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">TRANSCODING and CONFERENCING Credit Allocation</SPAN></A><o:p></o:p></H1>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Now that we understand credit allocation and channel capacity on each dsp, let’s look out how this affects media resources provisioning in a gateway.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Each media resource is allocated a fixed credit depending on the dsp that will be used. This is similar to the voice termination we have just covered.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">To find out the credits assigned to each media resource we use the command<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">“Show voice dsp capabilities”<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">#sh voice dsp capabilities slot 0 dsp 1 (PVDM3-128)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>645 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>20,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;">Conference 8-party credits:<o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">#sh voice dsp capabilities slot 0 dsp 1 (PVDM3-32)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Card 0 DSP id 1 Capabilities:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>480 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>34,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>22,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>FC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>14,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>21,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></B></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">Conferencing:</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">On a PVDM3-128, each 8 party conference uses 92 (actually about 92.25) credits for a G729 conference and 40 credits for a G711 conference. Hence for a total of 4 G729 conference sessions we will have 92*4 =368 approximated to 369.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">On dsp3, 18 channels were allocated for voice which totalled 276 credits, leaving only 369 credits. Hence when you try to configure max sessions for your conference you will only have 4 sessions available.<o:p></o:p></SPAN></SPAN></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">Transcoding:</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The credit used by each transcoding session/channel will depend on the complexity of the transcoder. Transcoding uses the same credits as the complexity mode for voice termination.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">e.g On a PVDM3-128<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">HC Credits =32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>=20<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">In this example from the output of the show voice dsp capabilities, HC credit=32 <SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>(actually 32.25)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Hence to have a total of 14 transcoding sessions, you will need 14*32.25 credits = approx. 452 credits.<o:p></o:p></SPAN></SPAN></SPAN></P>
<H2 style="MARGIN: 10pt 0cm 0pt" mcestyle="margin: 10pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #4f81bd; FONT-SIZE: 14pt" mcestyle="font-family: Cambria; color: #4f81bd; font-size: 14pt;">PVDM3-64 DSP ALLOCATION EXAMPLE</SPAN></A><o:p></o:p></H2>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Let’s look at another example of resource allocation on a PVDM3-64 dsp.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">This example uses the following configurations…<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">#sh run | b dspfarm profile<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">dspfarm profile 1 transcode<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g711ulaw<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g711alaw<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g729ar8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g729abr8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g729r8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>maximum sessions 10<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>associate application SCCP<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">!<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">dspfarm profile 2 conference<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>codec g729br8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>maximum sessions 6<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">voice-port 0/1/0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>trunk-group SRSTPSTN 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>supervisory disconnect dualtone mid-call<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>input gain 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>output attenuation -3<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>cptone GB<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>timeouts call-disconnect 5<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>timeouts wait-release 5<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>connection plar opx 200<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>impedance complex2<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">voice-port 0/1/1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>trunk-group SRSTPSTN 2<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Let’s start by looking at the dsp capabilities on this PVDM<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">#sh voice dsp capabilities slot 0 dsp 1<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">DSP Type: SP2600 -32<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Card 0 DSP id 1 Capabilities:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>480 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711Credits 15,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>34,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Credits<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>22<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>FC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>32,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>HC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>14,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>MC Channel<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>21,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Conference 8-party credits:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G711<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>36 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G729<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>96 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>G722<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>96 ,<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>ILBC<SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>120-<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">We can see that<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpFirst" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l0 level1 lfo3;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">HC credits=34 (actually 34.33)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpLast" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 10pt 36pt; mso-list: l0 level1 lfo3;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">G729 8-part conference =96<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></B></P>
<P class="MsoNormal" mcestyle="line-height: normal; margin: 0cm 0cm 10pt;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Now let’s see how the dsp allocation was done..<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">#sh voice dsp group all (1 dsp used for voice, xcoding and conferencing)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">DSP groups on slot 0:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">dsp 1:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>State: UP, firmware: 26.3.8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max signal/voice channel: 32/32<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max credits: 480<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>num_of_sig_chnls_allocated: 32<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Transcoding channels allocated: 10----
10 xcoding channels at 34.33 credits/channel <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_VOICE, complexity: FLEX<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 41, reserved credits: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Signaling channels allocated: 2</B>----
2 channels for 2 voice ports<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Voice channels allocated: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Credits used (rounded-up): 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_XCODE, complexity: HIGH<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 0, reserved credits: 343<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Transcoding channels allocated: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;">Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 0, reserved credits: 96</B>----
1 conference session<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Codec: CONF_G729, maximum participants: 8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Sessions per dsp: 5<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Slot: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Device idx: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>PVDM Slot: 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Dsp Type: SP2600<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">dsp 2:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Max signal/voice channel: 32/32<B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><o:p></o:p></B></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN></B>Max credits: 480<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><B style="mso-bidi-font-weight: normal" mcestyle="mso-bidi-font-weight: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 0, reserved credits: 480<o:p></o:p></SPAN></SPAN></SPAN></B></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Analysis…<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">We can see the following:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Dsp 1: <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpFirst" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l3 level1 lfo4;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">Max credits: 480<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l3 level1 lfo4;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">Signaling channels allocated: 2 (This is for the two voice-ports)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpLast" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 10pt 36pt; mso-list: l3 level1 lfo4;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">Group: FLEX_GROUP_XCODE, complexity: HIGH<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 0, reserved credits: 343 (a total of 343 credits were reserved for 10 transcoding sessions. This figure is calculated as 34.33*10 rounded up to 343<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN><o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpFirst" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l1 level1 lfo5;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; margin: 0cm 0cm 0pt 36pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Shared credits: 0, reserved credits: 96 (A total of 96 credits was reserved for 1 G729 conference)<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; margin: 0cm 0cm 0pt 36pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; margin: 0cm 0cm 0pt 36pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">Now observe that the remaining 5 conference sessions will be allocated to dsp 2.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; margin: 0cm 0cm 0pt 36pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;">DSP2:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l1 level1 lfo5;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">Max credits: 480<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; text-indent: -18pt; margin: 0cm 0cm 0pt 36pt; mso-list: l1 level1 lfo5;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol" mcestyle="font-family: Symbol; mso-fareast-font-family: Symbol; mso-bidi-font-family: Symbol;"><SPAN style="mso-list: Ignore" mcestyle="mso-list: Ignore;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;">·</SPAN><SPAN style="FONT: 7pt 'Times New Roman'" mcestyle="font: 7pt 'Times New Roman';"> </SPAN></SPAN></SPAN><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Group: FLEX_GROUP_CONF, complexity: CONFERENCE<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpMiddle" mcestyle="line-height: normal; margin: 0cm 0cm 0pt 36pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;"><SPAN style="mso-spacerun: yes" mcestyle="mso-spacerun: yes;"> </SPAN>Shared credits: 0, reserved credits: 480<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoListParagraphCxSpLast" mcestyle="line-height: normal; margin: 0cm 0cm 10pt 36pt;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Calibri" mcestyle="font-family: Calibri;">Each G729 conference takes 96 credits, 480/96=5. Hence we have the total of 6 conference sessions provisioned as configured.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormal" mcestyle="line-height: normal; text-indent: 36pt; margin: 0cm 0cm 10pt;"><o:p><SPAN style="FONT-FAMILY: Calibri; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Calibri; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">Difference between PVDM2 and PVDM3</SPAN></A><o:p></o:p></H1>
<P class="MsoNormalCxSpFirst" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The example above shows one the major difference between PVDM2 and PVDM3. In a PVDM2, dsp conferencing can’t not be shared with any other dsp. When a dsp is allocated for conferencing, it is dedicated; this is because a special firmware is loaded unto the dsp.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Example<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 1: <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">State: UP, firmware: 4.4.20 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max signal/voice channel: 16/16 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Max credits: 240 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Group: FLEX_GROUP_VOICE, complexity: FLEX <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Shared credits: 210, reserved credits: 0 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Signaling channels allocated: 0 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Voice channels allocated: 1 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Credits used: 30 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Voice channels: <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Ch01: voice port: 0/0/0:23.1, codec: g711ulaw, credits allocated: 30<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp 2: <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">State: UP, firmware: 1.0.6 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Group: FLEX_GROUP_CONF, complexity: CONFERENCE <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Shared credits: 0, reserved credits: 240 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Conference session: 2 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Credits used: 0 <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><o:p><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></o:p></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">We can see that the dsp2 above was dedicated for conferencing and the firmware on it is different to the other dsp. Even though there are just 2 conference sessions, the whole of 240 credits were reserved. <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpLast" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: Cambria; COLOR: #365f91" mcestyle="font-family: Cambria; color: #365f91;">DSP hunting order</SPAN></A><o:p></o:p></H1>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Cisco IOS searches for dsp to allocate for either voice termination, transcoding and conference in a particular order. To know the hunt order you can use the following command<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p><SPAN style="TEXT-DECORATION: none" mcestyle="text-decoration: none;"><SPAN style="FONT-FAMILY: Times New Roman; COLOR: #000000; FONT-SIZE: 12pt" mcestyle="font-family: Times New Roman; color: #000000; font-size: 12pt;"> </SPAN></SPAN></o:p></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">“show voice dsp sorted-list slot x” where x is the slot number<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">#sh voice dsp sorted-list slot 0<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">DSP id selection list for different service for Card 0:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">========================================================<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Note: analog voice ports allocate DSPs with least credits<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">to most credits during boot up for this voice card<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Voice :01,02,03<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Conf 0 :03,02,01<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Xcode :01,02,03<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">From the Above, dsp1,2 and 3 will be used for voice termination, dsp3,2,1 will be used for Conferencing. This is the reason why you see that even though the second and first dsps have credits available on them, conferencing is allocated to the 3
<H1 style="MARGIN: 24pt 0cm 0pt" mcestyle="margin: 24pt 0cm 0pt;"><SPAN style="FONT-FAMILY: ; COLOR: #365f91" mcestyle="color: #365f91;"><SPAN style="FONT-FAMILY: Cambria" mcestyle="font-family: Cambria;"><SPAN style="FONT-WEIGHT: normal" mcestyle="font-weight: normal;">DSP numbering</SPAN></SPAN><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">:</SPAN></SPAN></SPAN></A><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><o:p></o:p></SPAN></H1>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Sometimes when we have a combination of dsps, we do see often times some funny numbering and we don’t quite understand how these came about.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM3 Only <o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">On a PVDM3 only installation, each PVDM slot is numbered for the maximum amount of dsp that it can accommodate, even if there are fewer dsps installed.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Example Let’s look at this combination<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot0: PVDM3-256<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot1:PVDM3-16<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot1:PVDM3-64<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">This is how the dsp will be numbered..<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot0: <o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Dsp1,2,3,4,5,6<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot1:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp7<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot2:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp13,14<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">The reason behind this is this…slot 1 can take a maximum of 6 dsps but only 1 dsp has been installed, so the numbering for the other 5 is kept intact. Hence cisco IOS count 7,8,9,10,11,12 and then IOS goes to the next number which is 13.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">PVDM2 only<o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">On a PVDM2, the maximum dsp you have is 4. So each dsp is numbered to account for this even if the number of dsp is less.<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Lets look at this combination<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot0: PVDM2-32<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot1:PVDM2-64<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot2:PVDM2-16<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">This is how the dsp will be numbered<SPAN style="TEXT-DECORATION: underline" mcestyle="text-decoration: underline;">..<o:p></o:p></SPAN></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Dsp1,2,<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">dsp5,6,7,8<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Slot3:<o:p></o:p></SPAN></SPAN></SPAN></P>
<P class="MsoNormalCxSpMiddle" mcestyle="line-height: normal;"><SPAN style="FONT-FAMILY: ; FONT-SIZE: 12pt" mcestyle="font-size: 12pt;"><SPAN style="FONT-FAMILY: ; COLOR: #000000" mcestyle="color: #000000;"><SPAN style="FONT-FAMILY: Times New Roman" mcestyle="font-family: Times New Roman;">Dsp 9
