Vaijanath Sonvane
This document outlines the procedure to customize ringtones for Cisco IP Phone 8800 Series on Cisco Unified CME Platform:
1. Create a new folder on your computer and name it as Ringtones
2. Keep all your ringtones (.raw) files, RingList.xml, Ringlist-wb.xml and DistinctiveRingList.xml files in it.
3. Use 7-Zip software to create .tar file. The final result is: Ringtones.tar
4. Open router CLI and copy tar from your computer to Router flash. You can use either TFTP or FTP software to upload files to Router flash. Below is the example using FTP:
CME# copy ftp://sftp:sftp@10.80.4.11/Ringtones.tar flash:/
In this example, Username: sftp, Password: sftp and CME IP Address: 10.80.4.11
5. Extract files on CME in the Ringtones directory using below command
CME# archive tar /xtract flash:/Ringtones.tar flash:/
6. Verify Ringtones directory using below command
CME# show flash: | in Ringtones/
<< output removed >>        /bootflash/Ringtones/Analog1.raw
<< output removed >>        /bootflash/Ringtones/Analog2.raw
<< output removed >>        /bootflash/Ringtones/AreYouThere.raw
<< output removed >>        /bootflash/Ringtones/AreYouThereF.raw
<< output removed >>        /bootflash/Ringtones/Bass.raw
<< output removed >>        /bootflash/Ringtones/CallBack.raw
<< output removed >>        /bootflash/Ringtones/Chime.raw
<< output removed >>        /bootflash/Ringtones/Classic1.raw
<< output removed >>        /bootflash/Ringtones/Classic2.raw
<< output removed >>        /bootflash/Ringtones/ClockShop.raw
<< output removed >>        /bootflash/Ringtones/DistinctiveRingList.xml
<< output removed >>        /bootflash/Ringtones/Drums1.raw
<< output removed >>        /bootflash/Ringtones/Drums2.raw
<< output removed >>        /bootflash/Ringtones/FilmScore.raw
<< output removed >>        /bootflash/Ringtones/HarpSynth.raw
<< output removed >>        /bootflash/Ringtones/Jamaica.raw
<< output removed >>        /bootflash/Ringtones/KotoEffect.raw
<< output removed >>        /bootflash/Ringtones/MusicBox.raw
<< output removed >>        /bootflash/Ringtones/Piano1.raw
<< output removed >>        /bootflash/Ringtones/Piano2.raw
<< output removed >>        /bootflash/Ringtones/Pop.raw
<< output removed >>        /bootflash/Ringtones/Pulse1.raw
<< output removed >>        /bootflash/Ringtones/Ring1.raw
<< output removed >>        /bootflash/Ringtones/Ring2.raw
<< output removed >>        /bootflash/Ringtones/Ring3.raw
<< output removed >>        /bootflash/Ringtones/Ring4.raw
<< output removed >>        /bootflash/Ringtones/Ring5.raw
<< output removed >>        /bootflash/Ringtones/Ring6.raw
<< output removed >>        /bootflash/Ringtones/Ring7.raw
<< output removed >>        /bootflash/Ringtones/RingList.xml
<< output removed >>        /bootflash/Ringtones/Sax1.raw
<< output removed >>        /bootflash/Ringtones/Sax2.raw
<< output removed >>        /bootflash/Ringtones/Vibe.raw
<< output removed >>        /bootflash/Ringtones/Ringlist-wb.xml
7. Configure below commands at global configuration level:
CME(config)# tftp-server flash:Ringtones/Analog1.raw alias Analog1.raw
CME(config)# tftp-server flash:Ringtones/Analog2.raw alias Analog2.raw
CME(config)# tftp-server flash:Ringtones/AreYouThere.raw alias AreYouThere.raw
CME(config)# tftp-server flash:Ringtones/AreYouThereF.raw alias AreYouThereF.raw
CME(config)# tftp-server flash:Ringtones/Bass.raw alias Bass.raw
CME(config)# tftp-server flash:Ringtones/CallBack.raw alias CallBack.raw
CME(config)# tftp-server flash:Ringtones/Chime.raw alias Chime.raw
CME(config)# tftp-server flash:Ringtones/Classic1.raw alias Classic1.raw
CME(config)# tftp-server flash:Ringtones/Classic2.raw alias Classic2.raw
CME(config)# tftp-server flash:Ringtones/ClockShop.raw alias ClockShop.raw
CME(config)# tftp-server flash:Ringtones/Drums1.raw alias Drums1.raw
CME(config)# tftp-server flash:Ringtones/Drums2.raw alias Drums2.raw
CME(config)# tftp-server flash:Ringtones/FilmScore.raw alias FilmScore.raw
CME(config)# tftp-server flash:Ringtones/HarpSynth.raw alias HarpSynth.raw
CME(config)# tftp-server flash:Ringtones/Jamaica.raw alias Jamaica.raw
CME(config)# tftp-server flash:Ringtones/KotoEffect.raw alias KotoEffect.raw
CME(config)# tftp-server flash:Ringtones/MusicBox.raw alias MusicBox.raw
CME(config)# tftp-server flash:Ringtones/Piano1.raw alias Piano1.raw
CME(config)# tftp-server flash:Ringtones/Piano2.raw alias Piano2.raw
CME(config)# tftp-server flash:Ringtones/Pop.raw alias Pop.raw
CME(config)# tftp-server flash:Ringtones/Pulse1.raw alias Pulse1.raw
CME(config)# tftp-server flash:Ringtones/Ring1.raw alias Ring1.raw
CME(config)# tftp-server flash:Ringtones/Ring2.raw alias Ring2.raw
CME(config)# tftp-server flash:Ringtones/Ring3.raw alias Ring3.raw
CME(config)# tftp-server flash:Ringtones/Ring4.raw alias Ring4.raw
CME(config)# tftp-server flash:Ringtones/Ring5.raw alias Ring5.raw
CME(config)# tftp-server flash:Ringtones/Ring6.raw alias Ring6.raw
CME(config)# tftp-server flash:Ringtones/Ring7.raw alias Ring7.raw
CME(config)# tftp-server flash:Ringtones/Sax1.raw alias Sax1.raw
CME(config)# tftp-server flash:Ringtones/Sax2.raw alias Sax2.raw
CME(config)# tftp-server flash:Ringtones/Vibe.raw alias Vibe.raw
CME(config)# tftp-server flash:Ringtones/RingList.xml alias RingList.xml
CME(config)# tftp-server flash:Ringtones/Ringlist-wb.xml alias Ringlist-wb.xml
CME(config)# tftp-server flash:Ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
8. Verify Ringtones on Cisco 8800 Series IP Phones.
For your reference, I have attached Ringtones.tar file with this document.
