Mohit Grover
Level 2
Level 2
I have a WS-C3560-48PS switch, it was working all fine suddenly it stopped providing power to all ports, now I am getting following error message "Command rejected: power inline static: pwr not available Fa0/X"
MOGROVER_SWITCH(config)#int f0/5
MOGROVER_SWITCH(config-if)#power inline static max 15400
Command rejected: power inline static: pwr not available Fa0/5
Here is the "show power inline" output: !! after hitting "power inline never" command
!! Admin status is off which is expected after "power inline never" command
!! but Operational status is off & Power (Watts) = 0.0
MOGROVER_SWITCH#sh power inline
Available:0.0(w)  Used:0.0(w)  Remaining:0.0(w)
Interface Admin  Oper       Power   Device              Class Max
                            (Watts)
Fa0/1     off    off        0.0     n/a                 n/a   15.4
Fa0/2     off    off        0.0     n/a                 n/a   15.4
Fa0/3     off    off        0.0     n/a                 n/a   15.4
Fa0/45    off    off        0.0     n/a                 n/a   15.4
Fa0/46    off    off        0.0     n/a                 n/a   15.4
Fa0/47    off    off        0.0     n/a                 n/a   15.4
Fa0/48    off    off        0.0     n/a                 n/a   15.4
MOGROVER_SWITCH#
MOGROVER_SWITCH(config)#int ran f0/1-48
MOGROVER_SWITCH(config-if-range)#power inline auto
!! following is the "show power online" output after hitting "power inline auto"
!! Admin status is auto but Operational status is off !!
!! Power (Watts) = 0.0
                            (Watts)
Fa0/1     auto   off        0.0     n/a                 n/a   15.4
Fa0/2     auto   off        0.0     n/a                 n/a   15.4
Fa0/3     auto   off        0.0     n/a                 n/a   15.4
Fa0/45    auto   off        0.0     n/a                 n/a   15.4
Fa0/46    auto   off        0.0     n/a                 n/a   15.4
Fa0/47    auto   off        0.0     n/a                 n/a   15.4
Fa0/48    auto   off        0.0     n/a                 n/a   15.4
MOGROVER_SWITCH#
MOGROVER_SWITCH(config-if-range)#power inline static max ?
  <4000-15400>  milli-watts
MOGROVER_SWITCH(config-if-range)#power inline static max 15400
Command rejected: power inline static: pwr not available Fa0/1
Command rejected: power inline static: pwr not available Fa0/2
Command rejected: power inline static: pwr not available Fa0/3
Command rejected: power inline static: pwr not available Fa0/4
Command rejected: power inline static: pwr not available Fa0/46
Command rejected: power inline static: pwr not available Fa0/47
Command rejected: power inline static: pwr not available Fa0/48
  • Brief summary
Switch was in service, with powered IP phones connected and operational.
  • Troubleshooting Done
  1. Shut & no shut the ports
  2. Power reset switch, ensured ports were configured correctly.
  3. Set to power inline static still no power supplied to phones.
  • Solution
