cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: ashok kolwal on 11-10-2012 12:11:41 AM
Hi, All I am developing an application "Conference Bridge" using cisco jabber . I am able to makeCall to a single user but i am not able to makeCall to multiple user for conference.I had alrady try with cisco jabberSDK sample.html code but it is not working for conference how can I do it? Please reply me ASAP. Thanks & Regards, Ashok Kolwal
Subject: RE: conference call using cisco jabberSDK
Replied by: David Staudt on 11-10-2012 11:13:23 AM
Need some clarification, and there are some caveats you may need to consider:
- Are you attempting to automate a Jabber client?  If so, is it Jabber for Windows/MAC or perhaps iPhone/Android?
- Are you attempting to automate a custom application created using the Jabber SDK?
- Are you using UCXSI to attempt to automate Jabber?
To my knowledge:
- UCXSI supports automating only SCCP protocol endpoints, not SIP.  Jabber (client or SDK) is implemented via SIP and may not be supported by UCXSI
- UCXSI does not include commands for creating conference calls
If you are trying to do something more specific, please give us more details...
Replied by: Cisco Service on 05-09-2013 09:25:35 AM
Hi...
did You get Your app to work? I am not sure whether cisco
will continue support for UCXSI as the latest sdk version is already 2
years ago and the new phones 99xx, 89xx, 69xx are not supported as they
only work with SIP. Do You have an idea how to make a call from a SIP
phone?
Best regards, Martin
