cdnadmin
Community Member
This document was generated from CDN thread
Created by: Grant Bagdasarian on 24-06-2013 07:24:12 AM
Using Cisco 3925 - IOSVersion 15.2(3)T. No CVP. VoiceXML applications are registered on incoming dial-peers.
I'm receiving an error for the following VoiceXML document.
 1<?xml version="1.0" encoding="UTF-8"?>
 2<vxml version="2.1" xmlns="http://www.w3.org/2001/vxml">
 3<menu>
 4<prompt>
 5<audio src="welcome.wav"/>
 6</prompt>
 7<choice dtmf="1" next="/vxml/answer?id=1"/>
 8<choice dtmf="2" next="/vxml/answer?id=2"/>
 9</menu>
10</vxml>
Jun 24 12:07:19.199: //224522//AFW_:/vapp_asr_define_grammar:
Jun 24 12:07:19.199: //224522//AFW_:/vapp_asr_define_grammar:  grammar_id=session:[email protected]
Jun 24 12:07:19.199: //224522//AFW_:/vapp_asr_define_grammar:  encoding_name=UTF-8
Jun 24 12:07:19.199: //224522//AFW_:/vapp_asr_define_grammar:  remoteupdate=0
Jun 24 12:07:19.199: //224522//AFW_:/vapp_asr_define_grammar: grammar=<?xml version="1.0" encoding="UTF-8"?><grammar version="1.0" xmlns="http://www.w3.org/2001/06/grammar" mode="dtmf" root="root"><rule id="root" scope="public">1</rule></grammar>
Jun 24 12:07:19.199: //224522/7373C953A866/VXML:/vxml_vapp_asr_define_grammar:
   CALL_ERROR; [HIDDEN_URL]
   at line 1: fail with vapp error 2
Subject: RE: Grammer error with choice element
Replied by: Raghavendra Gutty Veeranagappa on 24-06-2013 08:11:27 AM
Hi Grant,
 i tested your script i did not see any error, could you please send full logs with below debugs.
debug voip app.
Ragahvendra
Replied by: Grant Bagdasarian on 24-06-2013 08:24:25 AM
Is there a way to enable debugging on a single dial-peer or filter the show logging to only include debug output from the associated dial-peer? We are currently running about 40 TCL service instances which are polling for outbound calls to place. This generates a massive amount of logging when I enable the debug voip app command. It's practically unreadable.
Does this error have something to do with ASR (Automatic Speech Recognition)? Because I see vapp_asr_define_grammer which is generating the error. We don't have ASR or TTS enabled on this machine.
Replied by: Grant Bagdasarian on 25-06-2013 12:50:24 AM
Why is this piece of VoiceXML markup so dependent on speech recognition? It's just simple DTMF? Shouldn't the machine be able to handle this?
I usually do DTMF like below, and that works fine.
 1<field name="ChosenDigit">
 2<prompt>
 3<audio expr="MediaDirectory + 'welcome.wav'" />
 4</prompt>
 5<grammar type="application/grammar+regex">.</grammar>
 6</field>
 7<filled>
 8<assign name="Value" expr="ChosenDigit" />
 9</filled>
Replied by: Raghavendra Gutty Veeranagappa on 25-06-2013 12:41:56 AM
Hi Grant,
yes this error is related ASR server,i am also seeing same error if i remove asr-server.You need to configure below commands in your router.
ivr asr-server rtsp://<ipaddress>/recognizer
ivr tts-server rtsp://<ipaddress>/synthesizer
Raghavendra
Replied by: Raghavendra Gutty Veeranagappa on 25-06-2013 01:29:38 AM
Hi Grant,
To handle DTMF input, Cisco VoiceXML uses either an external media server or the Cisco voice gateway, which is capable of handling all DTMF applications.
For an external media server to collect DTMF input, use W3C XML grammar. For a Cisco voice gateway to collect DTMF input, use Cisco specific DTMF grammar.
I think in previous case it is W3C XML grammar and in this case it is CIsco DTMF grammar, For user input using W3C XML grammar, an external media server is required.
For More information please refer grammar section in VoiceXML programming Guide in below link.
Raghavendra
Replied by: Grant Bagdasarian on 28-06-2013 01:20:21 AM
Alright, thank you for your help.
corretordetextopro
Community Member
Interesting discussion. While the issue here is related to VoiceXML grammar processing and ASR configuration, I also noticed several references to spelling and grammar terminology throughout the thread.
When reviewing technical documentation, developer guides, or support articles, I usually use Corretor De Texto Pro to identify spelling and grammar issues before publishing:
https://corretordetextopro.com.br/
Clear documentation helps developers troubleshoot problems more efficiently and reduces confusion when working with complex configurations.
