Teck Chye Tang
The attached document details the method and procedure to load the TC series software to the codec from scratch.  Document is written based on the used of Cisco TFTP server v1.1 (http://www.brothersoft.com/cisco-tftp-server-220729.html)
Requirements:
a) TC software
b) TFTP server
c) Serial cable
d) u-boot.bin file (attached)
e) pkgextract.elf file (attached)
Applicable to the following codec (as of now) :
a)     C20
b)     C40
c)     C60
d)     C90
e)     EX60
f)      EX90
g)     MX200
h)     MX300
i)      SX20
Not applicable
Hello, I think pkgfiles_uboot.rar.zip is for C40 or else, because then try make this for my C20 - get error.
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  4
ORION> setenv serverip xxx.xxx.134.206
ORION> setenv tftp_path pkgfiles
ORION> setenv orionpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.209
NAND erase: device 0 whole chip
Skipping bad block at  0x09b40000
Skipping bad block at  0x0ea40000
Skipping bad block at  0x27640000
Skipping bad block at  0x48700000
Skipping bad block at  0x4d980000
Skipping bad block at  0x582c0000
Skipping bad block at  0x7cb40000
Erasing at 0x7ffc0000 -- 100% complete.
OK
yaffs: Mounting /flash
Using TSEC0 device
TFTP from server xxx.xxx.134.206; our IP address is xxx.xxx.134.209
Filename 'pkgfiles/saturn.pkg'.
Load address: 0x2000000
Loading: *
TFTP error: 'File not found??f•wabcdefghi??×ö' (1)
Not retrying...
Copy pkgextract.elf from NOR flash to 0x1000000
## Starting application at 0x00042e78 ...
Buildtime: Jan  4 2012 11:31:59
Not a PKG file (170173190)
Failed to read PKG header
## Application terminated, rc = 0x1
image1 is not a directory
Reprogram NOR from /flash/image1
Un-Protected 1 sectors
. done
Erased 1 sectors
Copy /flash/image1/bootsw to 0x01000000... File not found
Write /flash/image1/bootsw (4294967295) to NOR flash
NOR allready contains correct data
Copy /flash/image1/pkgextract.elf to 0x01000000... File not found
Write /flash/image1/pkgextract.elf (4294967295) to NOR flash
File /flash/image1/S01710.bin.wrapper not found
ORION> Orion
Unknown command 'Orion' - try 'help'
ORION>        SN: F1AN2
Unknown command 'SN:' - try 'help'
ORION>        SN: PB039 TSEC1
ORION> Hwmon: 43
Unknown command 'Hwmon:' - try 'help'
ORION> Press erverip 210tc2_0_1.pkg
Unknown command 'Press' - try 'help'
ORION> ORION> run pkgexe: device 0 whole chip
Unknown command 'ORION>' - try 'help'
ORION> Skipping bad blox27640000
Unknown command 'Skipping' - try 'help'
ORION> Skipping bad blo582c0000
ORION> Skipping bad blo/flash
ORION> Using TSE0 device 'pkgfiles/saturn.pkg'.
Unknown command 'Using' - try 'help'
ORION> Load address: 0xretrying...
Unknown command 'Load' - try 'help'
ORION> Copy pkgextract.Buildtime: Jan  4 2012 11:31:59
Unknown command 'Copy' - try 'help'
ORION> Not a PKG file (image1 is not a directory
Unknown command 'Not' - try 'help'
ORION> Reprogram NOR frlash/image1/bootw to 0x01000000... File not found
Unknown command 'Reprogram' - try 'help'
ORION> Write /flash/imaflash/image1/pkgextract.elf to 0x01000000... File not fou
nd
Unknown command 'Write' - try 'help'
ORION> Write /flash/imadata
ORION> File /flash/imag
Teck Chye Tang
ORION> setenv orionpkg s52000tc2_0_1.pkg .......
The above command should be setenv saturnpkg s52000tc2_0_1.pkg....
no need to change the name to that of the codec used.  Just leave it as saturn.
Still same error. There is Log:
ORION> setenv serverip xxx.xxx.134.247
ORION> setenv saturnpkg s52000tc2_0_1.pkg
ORION> run pkgex
BOOTP broadcast 1
DHCP client bound to address xxx.xxx.134.214
save exit: isCheckpointed 1
OK
Using TSEC0 device
TFTP from server xxx.xxx.134.247; our IP address is xxx.xxx.134.214
Filename 'pkgfile/s52000tc2_0_1.pkg'.
Loading: *
TFTP error: 'File not foundô"…2' (1)
Not retrying...
. done
Erased 1 sectors
I think the reason of this error can be - not correctly working Cisco TFTP server, because it dont show any Logs, any activity then try upload software.
Maybe I do something wrong.
I set for Cisco TFTP server root address (C:\Program Files\Cisco Systems\Cisco TFTP Server\pkgfile). Maybe need make some more in this?
John Regan
You are trying to load TC2.0.1 for some reason (s52000tc2_0_1.pkg).  C40s only support TC3 as minimum and I would recommend that you uploaded a more recent version than that.
This will not help you file not found message but trying to upload TC2.0.1 will not help you.  What files do you have in your pkgfile directory?
John
Hello, I try upload software to our Tandberg C20 demo.
in pkgfile directory is this three files:
s52000tc2_0_1.pkg
pkgextract.elf
u-boot
The command to start upload is this:
run pkgex
Teck Chye Tang
setenv saturnpkg s52000tc2_0_0.pkg, is this s typing misake?  should be s52000tc2_0_1.pkg
Suggest you run through this with a TAC's help to see if everything is done correctly.
Else, codec might really be having an issue.
Hi again, I uploded software sucessful - Just install SolorWind TFTP server and everything become good. So Thanks for help
Hes
Is there also such a process for the E20?
I only have image1 and not image2, this seems to be corrupted.
Image1 has an unknown password (admin and root account password unknown).
** Presentation ## doesn't work
Switching images by pressing 4 and 6 obviously doesn't work also, I only get the SNOOPY> prompt then.
Just being able to reset the password would be fine too...
Hes
Managed to log in as root now and deleted config.db to reset the password.
Seems that Putty didn't understand my breaks and had to use the menu for this.
Upgraded and now have two images again.
Not applicable
Still having issue with errors can't get karnel image, what can i do?
Daniel Ruiz
Good Afternoon I have an issue with my tandberg c90
At the start in "SATURN>" I see "SATURNII>" and not allow me to install the computer software any thoughts on this??
Daniel Ruiz
I get the following on startup
SATURNII>
U-Boot 2010.06-107 (Sep 28 2012 - 08:20:46) MPC83XX
Reset Status:
CPU:   e300c1, MPC8347_TBGA_EA, Rev: 3.0 at 600 MHz, CSB: 200 MHz
I2C:   ready
DRAM:  DDR2 RAM: 512 MiB
RAM data bus test       [PASS]
RAM address bus test    [PASS]
FLASH: 4 MiB
NAND:  2048 MiB
RTC:   2013-07-26 (Friday) - Time: 19:33:08
PCI Video Processor Detection   [PASS]
Saturn main board
        Rev: G
        SN: PH1194576
        Object level: 33
        MAC: 00:50:60:84:0F:EF
SaturnII video board
        Rev: G
        SN: PH1195215
        Object level: 10,12
Saturn audio extension board
        Rev: E
        SN: PH1194502
        Object level: 04
Net:   TSEC0, TSEC1
Hwmon: 45
Eth:   Configure the external switch
Press 'c' to stop autoboot:  0
yaffs: restored from checkpoint
Configure FPGAs
FPGA configuration failed
Setting up Davinci HD (01.00.00)... 675Mhz       [DONE]
Setting up Davinci HD (01.01.00)... 675Mhz       [DONE]
Setting up Davinci HD (01.02.00)... 675Mhz       [DONE]
Setting up Davinci HD (01.03.00)... 675Mhz       [DONE]
Setting up Davinci HD (02.00.00)... 675Mhz       [DONE]
Setting up Davinci HD (02.01.00)... 675Mhz       [DONE]
Setting up Davinci HD (02.02.00)...1000Mhz       [DONE]
Setting up Davinci HD (02.03.00)...1000Mhz       [DONE]
Setting up Davinci HD (02.04.00)...1000Mhz       [DONE]
Setting up Davinci HD (02.05.00)...1000Mhz       [DONE]
Copy /flash/active/arm/rootfs to 0x03000000... File not found
Error: filesize must be > 0
Copy /flash/active/arm/kernel to 0x02000000... File not found
Copy /flash/active/arm/u-boot.bin to 0x01000000... File not found
Copy /flash/active/kernel to 0x01000000... File not found
Copy /flash/active/rootfs to 0x02000000... File not found
Copy /flash/active/dtb to 0x03000000... File not found
Wrong Image Format for bootm command
ERROR: can't get kernel image!
SATURNII>
MinyuVV_14
Please help to resolve the boot failure with sx20
ASTERIX> run pkgex
## Error: "pkgex" not defined
