cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Mohamed Nadjib HAMMOUDI on 16-05-2012 05:03:17 AM
I'm developping AXL access to get perfmon objects (Processor object for instance) and it works just fine, but when comparing values returned from Perfmon web service (perfmonCollectCounterData operation) and those returned from RTMT it is clear that they are wrong because all values are 0!!!
Here is the XML returned from the PerfmonPort.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<ns1erfmonCollectCounterDataResponse xmlns:ns1="http://schemas.cisco.com/ast/soap/" soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<ArrayOfCounterInfo xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/" soapenc:arrayType="ns1:CounterInfoType[40]" xsi:type="soapenc:Array">
<item xsi:type="ns1:CounterInfoType">
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\% CPU Time</Name>
<Value xsi:type="xsd:long">0</Value>
<CStatus xsi:type="xsd:unsignedInt">1</CStatus>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\IOwait Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\Idle Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\Irq Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\Nice Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\Softirq Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\System Percentage</Name>
</item>
<Name xsi:type="ns1:CounterNameType">\\10.207.16.1\Processor(_Total)\User Percentage</Name>
</item>
</ArrayOfCounterInfo>
</ns1erfmonCollectCounterDataResponse>
</soapenv:Body>
</soapenv:Envelope>
Nadjib
Subject: RE: Inconsistency between perfmonCollectCounterData and RTMT values
Replied by: Mohamed Nadjib HAMMOUDI on 16-05-2012 11:28:11 AM
Finally i found the explanation. Percentage counters require two samples to determine the average between the samples, but you have to use the session-based Perfmon operation (perfmonCollectSessionData) with 4 sec minimum between the samples.
Ravi Shekhar
hi Nadjib,
I am still unable to get the correct values by comparing. Here is what I am doing:
-Open a new session
-Add counter
-wait for 5 sec
-resend the Add counter request.
-get the session data
-close the session.
Can you let me know what is going wrong in this
