Anonymous
Not applicable
    When troubleshooting in Cisco Unified Communications Manager, it is sometimes necessary to collect packets which are being sent to and from the network interface on a CUCM server.  This document describes the process in four steps.
    1.  Starting the Capture
    To start the capture, establish a secure shell (SSH) session to the CUCM server authenticating with the Platform Administrator account:
    1a.  Command Syntax
         The command is "utils network capture" and the syntax is as follows:
    Syntax:
    utils network capture [options]
    options  optional
    page,numeric,file fname,count num,size bytes,src addr,dest addr,port
    num,host protocol addr
    options are:
    page
    - pause output
    numeric               - show hosts as dotted IP
    addresses
    file fname            - output the information to a file
    Note: The file will be saved in platform/cli/fname.cap
    fname should not contain the "." character
    count num             - a
    count of the number of packets to capture
        Note: The maximum count
    for the screen is 1000, for a file is 100000
    size bytes            -
    the number of bytes of the packet to capture
        Note: The maximum
    number of bytes for the screen is 128
              For a file it can be
    any number or ALL
    src addr              - the source address of the
    packet as a host name or IPV4 address
    dest addr             - the
    destination address of the packet as a host name or IPV4 address
    port
    num              - the port number of the packet (either src or dest)
    host
    protocol addr    - the protocol should be one of the following:
    ip/arp/rarp/all. The host address of the packet as a host name or IPV4
    address. This option  will display all packets to and fro that address.
    Note: If "host" is provided, do not provide "src" or "dest"
    1b.  Capturing all traffic
         For a typical capture, one might wish to collect ALL packets of ALL sizes from and to ALL address into a capture file called 'packets.cap'.  To do this simply execute on the admin CLI 'utils network capture eth0 file packets count 100000 size all'
    1c.  Capturing based on port number
    Troubleshooting a communications issue with Cluster Manager, it might be desireable to capture based on a specific port (8500) using the port option.
    Note: For more information about which services require communications on each port, refer to the TCP and UDP Port Usage Guide for the applicable version of CUCM.
    1d.  Capturing based on host
    In troubleshooting an issue with CUCM and a particular host, it may be necessary to use the 'host' option to filter for traffic to and from a particular host.
    Note: it may be necessary to exclude a particular host, in this case use  a "!" in front of the IP.    An example of this would be "utils network  capture eth0 file packets count 100000 size all host ip !10.1.1.1"
    2.  Reproduce the problem symptom or condition
    While the capture is running reproduce the problem symptom or condition so that the necessary packets are included in the capture.  If the problem is intermittent it may be necessary to run the capture for an extended period.  If the capture ends, it is because the buffer is filled, restart the capture and the previous capture will be automatically renamed so the previous capture should not be lost.   If a capture is needed for an extended period of time, it might be worthwhile to capture at the network level via other means such as using a monitor session on a switch.
    3.  Stopping the capture
    To stop the capture hold the Control key and press C on the keyboard.  This will cause the capture process to end and no new packets will be added to the capture dump.
    Once this is complete there will be a capture file stored on the server in the location 'activelog platform/cli/'
    4.  Collecting the capture from the server.
    Collecting the capture from the server is the final step.  The capture files will be stored in "activelog platform/cli/" location on the server.  One can transfer the files through CLI to an SFTP server or to the local PC using the Real Time Monitoring Tool (RTMT).
    4a.  Transfer capture file through the CLI to an SFTP server
              Use the command "file get activelog platform/cli/packets.cap" to collect the packets.cap file to  the SFTP server.
         Alternatively to collect all .cap files stored on the server, use 'file get activelog platform/cli/*.cap'
         Finally, fill in the SFTP server IP/FQDN, port, username, password, and directory information:
         The CLI should indicate success or failure of the file transfer to the SFTP server.
    4b.  Transfer capture file to local PC using the Real Time Monitoring Tool (RTMT)
                This option will not be available to servers running a 5.x CUCM version earlier than 5.1(1), or 6.x version earlier than 6.1(2).  See CSCsg13820 and CSCsm76349 for details.
              Launch the Real Time Monitoring Tool.  If it is not installed on the local PC, install the appropriate version from the CUCM Administration page Applications->Plugins menu. Click "System", then "Trace & Log Central", then double click "Collect Files".  Click "Next" through the first menu.
         In the second menu choose the checkbox for "Packet Capture Logs" on the server which the capture was performed, then click Next.
         On the final screen choose a time range when the capture was performed, and a download directory on the local PC:
         RTMT will close this window and proceed to collect the file and store it on the local PC in the specified location.
    terry duffy
    Thanks for this, it also works with UCCX version 12.
    Wonxie
    is the interface always eth0 ?
