01-22-2011 01:21 PM - edited 03-12-2019 09:35 AM
Network topology
IP Phone ==VLAN 422=== Router ==VLAN 426===CCME Router
Here’s “why” ,”how”, “What happens if” to the commands used in SIP Phone Registration to CCME.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
#### SIP Phones create Voip Dial-peers. so for SIP to SIP, SIP to H323 you need to allow the connections. SCCP phones create EFXS POTS dial-peer. By Default IP-IP call is blocked)(Random Fact).
fax protocol pass-through g711ulaw
modem passthrough nse codec g711ulaw
sip
bind control source-interface FastEthernet0/0.426
bind media source-interface FastEthernet0/0.426
### Bind Control and media to the interface with the same IP Address on source-address x.x.x.x . Else you will run into problems when you try to register Phones over a Layer 3 Link.
registrar server
### Needed for phone to register
voice register global
mode cme
### Change mode to CME
source-address 14.160.126.77 port 5060
### Should be the same as bind control and media when you have InterVLAN Routing
max-dn 10
max-pool 10
authenticate register
### Needed for the phone to authenticate with username password, in intervlan registeration setup
tftp-path flash:
### All the config files for the phones will be stored here.
create profile sync 0174426467043125
### Make sure you enter this command everytime you make some changes.!!!!!! Very IMP!
voice register dn 1
number 1234
### DN for the Phone
voice register pool 1
id mac 0023.5E17.D275
### Mac Address of the Phone trying to register. Which won’t be used an authentication method when registering in Intervlan register scenario
type 7942
### Make sure you have this in here.! Else SEP<MAC-ADDRESS>.config wouldn’t be created.
number 1 dn 1
### Assigning 1234 to line 1 on the phone
username cisco password cisco
### Credentials the phone uses when it tries to register in case of intervlan.
Relevant debugs
Received:
REGISTER sip:14.160.126.77 SIP/2.0
Via: SIP/2.0/UDP 14.160.122.228:5060;branch=z9hG4bKdf9fece6
From: <sip:1234@14.160.126.77>;tag=00235e17d2750005e833caa4-06d638ae
To: <sip:1234@14.160.126.77>
Call-ID: 00235e17-d2750004-cab2ccbc-7e3c35d6@14.160.122.228
Max-Forwards: 70
Date: Thu, 14 Oct 2010 07:04:30 GMT
CSeq: 103 REGISTER
User-Agent: Cisco-CP7942G/8.5.2
Contact: <sip:1234@14.160.122.228:5060;transport=udp>;+sip.instance=”<urn:uuid:00000000-0000-0000-0000-00235e17d275>”;+u.sip!model.ccm.cisco.com=”434″
Supported: replaces,join,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-3.0.0,X-cisco-xsi-7.0.1
Content-Length: 0
Reason: SIP;cause=200;text=”cisco-alarm:105 Name=SEP00235E17D275 Load=SIP42.8-5-2SR1S Last=config-retry-restart”
Expires: 3600
*Oct 14 07:08:12.015: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 14 Oct 2010 07:08:12 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 103 REGISTER
Content-Length: 0
*Oct 14 07:08:12.111: VOICE_REG_POOL: Register request for (1234) from (14.160.122.228)
*Oct 14 07:08:12.111: VOICE_REG_POOL: key(B99A11AB0176754A) added to nonce table
*Oct 14 07:08:12.111: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: <sip:1234@14.160.126.77>;tag=EA0947C-241F
CSeq: 103 REGISTER
WWW-Authenticate: Digest realm=”",nonce=”B99A11AB0176754A”,algorithm=MD5,qop=”auth”
Content-Length: 0
Received:
Via: SIP/2.0/UDP 14.160.122.228:5060;branch=z9hG4bK0ca509fe
Max-Forwards: 70
CSeq: 104 REGISTER
Authorization: Digest username=”cisco”,realm=”",uri=”sip:14.160.126.77″,response=”dd2a196551c5598102e71c0eac92d89a”,nonce=”B99A11AB0176754A”,cnonce=”4a16becc”,qop=auth,nc=00000001,algorithm=MD5
Content-Length: 0
Expires: 3600
*Oct 14 07:08:12.127: VOICE_REG_POOL: Register request for (1234) from (14.160.122.228)
*Oct 14 07:08:12.131: VOICE_REG_POOL: Contact matches pool 1 number list 1
*Oct 14 07:08:12.131: VOICE_REG_POOL: key(1234) contact(14.160.122.228) add to contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL: No entry for (1234) found in contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL: key(1234) contact(14.160.122.228) added to contact table
*Oct 14 07:08:12.131: VOICE_REG_POOL pool->tag(1), dn->tag(1), submask(1)
*Oct 14 07:08:12.131: VOICE_REG_POOL: Creating param container for dial-peer 40001.VOICE_REG_POOL pool->tag(1), dn->tag(1), submask(1)
VOICE_REG_POOL pool_tag(1), dn_tag(1)
*Oct 14 07:08:12.135: VOICE_REG_POOL: Created dial-peer entry of type 0
*Oct 14 07:08:12.135: VOICE_REG_POOL: Registration successful for 1234, registration id is 1
*Oct 14 07:08:12.143: VOICE REGISTER POOL-1 has registered. Name:SEP00235E17D275 IP:14.160.122.228 DeviceType:Phone
*Oct 14 07:08:12.143: VOICE_REG_POOL: Pool[1]: service-control (reset type: 2) message sent to sip:1234@14.160.122.228
*Oct 14 07:08:12.143: VOICE_REG_POOL: Contact matches pool 1 number list 1
*Oct 14 07:08:12.183: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 REGISTER
Content-Length: 0
*Oct 14 07:08:12.187: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 REGISTER
Contact: <sip:1234@14.160.122.228:5060>;expires=3600;x-cisco-newreg
Expires: 3600
Content-Length: 0
Let me know if anything is wrong
Hey Divin,
There are chances where your sip phone to CME may loop in registration here, in this scenario remove the AUTHENTICATE REGISTER COMMAND by issuing a " NO AUTHENTICATE REGISTER" command then issue a CREATE PROFILE & the reset the phone.
That will fix this issue
Look closely at the 1st REGISTER, Unauth and the next REGISTER
