azoupas
Dear all,
this week we announced brand new addition in Room kit portfolio :
The Room Kit Mini is ideal for small rooms/huddle spaces (approx 3 meters) for two to five people. It is built on the Room kit family platform offering unique quality, intelligence and usability.
Highlights:
- combines codec, camera, microphones, and speakers into a single device
- 4K HDMI output to connect to external display, CEC 2.0 support off course
- 4K Ultra HD digital camera
- wide120-degree field of view (fov), allows everyone in a huddle space to be seen
- Best overview feature : Automatically detects meeting participants and provides ideal framing
- 4K content sharing (wired or wirless)
- beam forming microphones / reduce background noise
- 85db SPL speakers
- comes with touch 10 for ease-of-use. Yould could add Join button(OBTP)/Calendar integration, in-room controls, etc.
- flexibility to register on-premises(CUCM/BE6K/Exp-C) or Webex cloud or work H323 standalone
- H.264 AVC and other  latest video standards
- Embedded encryption and security features
plus USB for laptop connectivity:
Connect your laptop via USB and use Room Kit Mini with Skype or Facebook or any laptop-based video software. Room kit Mini becomes your laptop's USB camera/speakers/microphone to give you the best camera and audio experience.
More information:
Cisco Webex Room Kit Mini Data Sheet
For partners :  Cisco Webex Room Kit Mini TDM Presentation
For partners:  Cisco Huddle spaces solutions (mentions also Webex Share and Webex Board)
https://collaborate.cisco.com/huddle/ - more info on huddle spaces
please rate the posts you find useful
you can follow this post if you like, in order to get updates
rgds
Alkiviadis
DISCLAIMER: this post was created in order to provide useful info to Cisco partners and customers in my area (Greece/Cyprus and Malta).  For official and updated information, please consult cisco documentation, datasheets and ordering guides.
MaureenAw1990
May I know what is the difference between Room Kit and Room Kit Mini? Looking at the spec sheets, both seems to be very similar.
azoupas
hi Maureen,
please have a look here: Cisco Video Endpoints overview and positioning
If you are a partner then this is also a useful preso ''Cisco Webex Room Kit Mini TDM Presentation''
found in salesconnect.cisco.com.
In summary, top differences are:
a) room size (room kit mini is designed for smaller rooms 3-4 meters, room kit fits best in rooms up to 6-7 meters). This recommendation is related to points mentioned below.
b) Room kit mini has embedded microphones and no option for table microphone.
    Room kit has embedded microphones but could also support table microphones.
c) Room kit mini has one HDMI output so you can have single display in the room.
    Room kit has two HDMI outputs so you could have 2 HDMI screen displays.
d) Room kit Mini has best overview feature but not speaketrack(don't really need speaker track in such small rooms). Room kit supports both Best overview and Speakertrack features.
e) One other difference that only Room kit mini has is USB port to use it with your laptop.
hope it helps
rgds
Alkiviadis
MaureenAw1990
Hi Alkiviadis,
Thanks for your reply. That is very helpful!
