Danny De Ridder
Preface
Starting from release TC5.1.0 a maintenance mode was added to the TelePresence software. This mode will kick in when a codec fails to boot or, in later releases, when a codec crashes. The user or engineer gets presented with a reduced set of commands to troubleshoot the system to determine whether the system is suffering a hardware or a software failure
Maintenance mode : access via telnet or ssh
When accessing the codec via the command line interface (telnet or ssh) as admin user, the user gets presented with a screen as shown below.
Server:/home/cisco # ssh admin@144.254.14.158
Welcome to the Cisco Telepresence maintenance shell.Type 'help' or '?' for help. ?          - User Commands - help         factoryreset pkgverify    selectsw     reboot       version      log          OK
The first thing that needs to be done is a capture of the logfiles. This can be done using the "log" command shown in the "User Commands" above. As soon as the command is executed, all logfiles from the codec are sent to the screen output, one after the other. It is paramount the ssh or telnet session is logging all screen output to a file which can then be attached to the service request.
User commands in maintenance mode
From this reduced shell one can reboot the codec.
reboot
Really reboot? [yes/no] yes
Rebooting.
Broadcast message from root@ex90-home (Mon Oct  8 13:20:37 2012):
The system is going down for reboot NOW!
OK
Other options are to execute a factoryreset, use selectsw to load a  known working image, verify the version and pkgverify to do a sanity  check of the current installed image. If the logfiles have been analyzed by the TAC and it has been determined the unit went into maintenance mode due to a software issue, we can fallback to the previous image, if one is present on the codec. Once the codec has been recovered, it can be upgraded to later release containing fix for the encountered bug.
Some versions have a rootsettings command too.
help
         - User Commands -
rootsettings log
OK
rootsettings ?
usage: rootsettings [on/serial/off/never/get]
Command to control root user availability:
  get               obtain current setting
  off               root user is not available
  never             root user permanently turned off
  serial [password] root user is available on serial port only
  on [password]     root user is available on all ports.
OK
rootsettings on
OK
rootsettings on cisco
Having root access gives the additional option of putting all logfiles in a tar file and send them to a server.
Note : Once in maintenance mode you can download the logs to a SCP server. -OR- via PC by using windows SCP application. Maybe you need to open root via the 'rootsettings on' command. The logs which need to be attach to the service request .
Login to the system as root and tar the files :
tar -cvf /tmp/log.tar /var/log/* /var/log/eventlog/*
gzip /tmp/log.tar
And then copy /tmp/log.tar.gz to a server.
Or use your PC with winscp to get the file.
Printing of IP address of codec when in maintenance mode (TC5.1.5 or later)
An important enhancement to maintenance mode is the printing of the  codec's IP address on the screen. Whether the address is obtained via  DHCP or statically assigned : the user will now get notified which  address to use to connect to the maintenance shell. The screen below was  taken using TC5.1.5 release. However, the layout of this screen might  change in TC6 release.
Maintenance mode : access via a web browser (TC6.0.1 or later)
Release TC6.0.1 added the possibility to use your web browser in order to connect to a codec running in maintenance mode. The user gets presented with the same user interface as when logged in as admin, however, some options are greyed out, i.e. they are not available. The user still has access to the diagnostics to retrieve the current and historical logfiles and he/she can upgrade the codec. Here again : first thing to do is retrieve both historical and current logfiles so they can be attached to the service request if/when you contact the TAC.
Marius Nedregaard
Really good and vaulable documentation.
//Marius
Can the logs be deleted? Customers have very strict guidelines for having no tracible info.
