Frank Hoeben
Is there a 64 bit compatible TSP avaible yet, or do we have to wait for Callmanager 8?
If the latter, does anyone have an ETA on Callmanager 8?
Update:
Here is the Cisco TSPx64 Plugin in Version 8.5.1.7-0. for x86 and x64 Systems.
https://supportforums.cisco.com/servlet/JiveServlet/download/6077-2-80901/cm-tsp-plugin-8.5.1.7-0.i386.zip
64bit TSP and media driver
TSP now supports 64bit TAPI applications natively on Windows 64Bit platform (Windows 2008 R2 & Windows 7 64bit). It also supports secure connection to CTI Manager.
Media Driver supports 64bit natively for end-point media termination on CTI devices. Support for SRTP is planned for future releases.
Legacy TSP Wave Driver does NOT support 64Bit. Wavedriver on 32 bit TSP will no longer be supported after Release 9.0.
Greeshma Bernad
Thank you for your posting and interest in the Cisco Support Community.  For best practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For technical questions related to a Cisco Product or Technology, we encourage you to post on the Network Professionals Forum (NetPro). For your specific issue, you can go to IP Telephony forum
cisco.service
Hi All,
one more question.
Is there a 64bit version of TSP available for use with UCM 8.0x?
Best regards,
Martin
daraiuscyruskeeka
Community Member
Is there a 64-bit version of the TSP available for UCM 8.0x?
Anyone going to help?
