TCC_2
Level 10
Level 10
Core Issue
It is not possible to block incoming calls based on Automatic Number Identifier (ANI), or calling number, information when Media Gateway Control Protocol (MGCP) is used.
Resolution
When Cisco CallManager-controlled MGCP is used, the only way to block incoming calls    from specific numbers (ANI) is to contact the service provider and have them block the number.
Incoming calls based on ANI (calling number) can be blocked with the H.323 gateway.
For information on how to block calls based on ANI (calling number) with an H.323 gateway, refer the document How to block incoming calls based on calling number and called number information with a Cisco IOS H.323 gateway.
For information on how to block incoming calls based on ANI and Dialed Number Identification Service (DNIS) on Cisco CallManager and Cisco IOS  voice gateways, refer How to block incoming calls on Cisco CallManager and Cisco IOS voice gateways based on ANI and DNIS information.
dudi_duay
You can now block calls using calling party information for CUCM ver 8.0 and up.
https://supportforums.cisco.com/docs/DOC-18367
