mvild
Sept 2017 Update
High-level supported features across mobile platforms: Android, iOS, and Windows Phone 8.
skilambi
Maureen
Thanks for sharing. It says Android is supported for CWMS but that's 2.0 which isn't out. In addition it doesn't call out limitations for WET from mobile like content sharing from mobile
Srini
mvild
Hi Srini, nice to hear from you!
Yes, this latest app for Android will support CWMS 2.0 which is coming soon.
As for limitations, no, this doc will not call that out.  In terms of content sharing for WET, that would be refer to in our roadmap information. Please contact me directly for more information.
Will CWMS 2.0 allow telepresence integration?
skilambi
No that is further out slated for 3.0 not committed.
mvild
Hi, thank you for the follow up question and thnk you Srini for commenting.
If there are further inquiries about CWMS specifically, it would be helpful to start a new discussion.
We appriciate your continued engagement.
skilambi
Maureen
It shows event center is now supported on IOS but I tried it just yesterday and it didn't work. Am I missing something?
mvild
Hi Srini!
In this latest feature summary I included what is coming in v7.0 for both Android and iOS.  They are both not yet in the app store but soon will be.  I guess I'm just excited about it!
I apologize for the potential confusion.
skilambi
I am excited too, definitely been waiting for that for a long time, now finally I can attend Cisco sessions using my IPAD
mvild
guothuan
thank you ,
i have seen the update ,so,
the name of the pdf file,should be WebEx Meetings Mobile Feature Summary_Feb 1 2015.pdf
not 2014
skilambi
Maureen
The resolution of the PDF is very poor. It seems hazy where the footnote number is mentioned, 2,4 all look fuzzy. Can we upload a higher resolution image? The previous versions were easier to read
mvild
Thanks Srini, I agree. Working on it and will repost.
Susan McEvilly
Level 4
Level 4
Maureen, thank you for the update!  This is a very helpful document.  Keep 'em coming  Thank you.!
skilambi
Thanks the resolution looks good now
krivanov
Do we have a more updated version of this document?
