Hi, it would be helpful if the login for the Cisco Community was the same as other Cisco sites, in that if you use DUO for 2 factor authentication, it would do a push, instead of you always manually having to open the app.
I have a post about it from the DUO board, but basically it seems like Cisco has this capability in other areas, but doesn't enable it for the Community login? Here's the link about it that I started with examples.
https://community.cisco.com/t5/duo-mobile-app/cisco-co-duo-doesn-t-do-push-only-other-sites/m-p/5269869
