08-24-2015 04:31 PM - edited 03-14-2019 03:08 PM
Hi Guys,
I have a scenario where a customer calls into an Agent. Both audio streams are recorded fine.
Next the Agent transfers the call to another Agent.
The conversation between the two Agents is recorded, so both audio streams.
Now the the first Agent completes the transfer.
The recording is now only one way. The customer voice (inbound) is the only stream recorded. The Agents stream is not recorded?
Has some come across this scenario?
All Agents have desktop recording enabled.
AQM 10.5
Ben
02-04-2016 11:37 PM
Hi Ben,
Do you solved this issue? We have the same problem with recording. Our recorder system is Red Box. Working on it till now...
Hope you can share us your solutions.
Thanks in advance.
Eric
02-08-2016 04:34 PM
Yeah, we did. We bumped it up to the latest SU for 10.5.
Cheers
Ben
