Basic hold loop script question
wmelickbts
I believe I have a basic question about the use of a script step...maybe someone can answer this for me?  I have a select resource step which sends callers to what I call a "hold loop" if a caller is queued.  Basically the hold loop does a play prompt telling the caller that all agents are busy then goes to a call hold and waits 60 sec. before checking agent availability.  The issue is that the play prompt step does not move on to the call hold step unless a caller presses something on the DTMF keypad and #.   Is there a way just to play an audio file and move on to the next step without any caller input required?
I found that the issue was with long silence in the .wav files themselves.  Some files had silence and some did not which is why I think I didn't catch it sooner.  I did some snipping with Audacity, re-uploaded the prompts and everything is working correctly.  Calls progress from play prompt to call hold without any problems now.
12 Replies 12
wmelickbts
Forgot to mention this is UCCX 10.6.1
Chris Deren
Can you post your script for review?
Sure basically it's like this:
Play Prompt ( -- Triggering Contact --, wavHold_str)
Call Hold ( -- Triggering Contact --)
Delay 60 sec
Call Unhold ( -- Triggering Contact --)
...then it does an agentsLoggedIn check from CSQ IPCC Express...if no agents logged in then goto a closed label step....if agents are still logged in then go back to the play prompt step and repeat.
I'm not sure if Play Prompt is the right step to use....basically I just need it to play a .wav file then go to call hold.   I don't see a pay to get the Call Hold step to play a .wav before putting the caller on hold.
Is the play prompt set as "interruptible"?
Yes...is that the problem?
No, that is correct, how about "Barge-in" and "Continue on Prompt Errors" under the Prompt tab?
How long is the "wavHold_str" prompt? What happens if you don't press anything?
Barge In is set to Yes
Continue On Prompt Errors is also set to Yes
The wavHold_str is maybe like 10 seconds long....basically saying "all agents are busy....your call is important and will be answered by the next agent....etc"
I waited about 60+ seconds and basically all I hear is silence....I haven't tried for a longer time.   If I press anything on the DTMF keypad and # then I get the call hold music OK (I see it progress to the next step doing a debug)....just that it never gets to that next step without some kind of caller input from the play prompt step.
Change "Barge In" to NO and re-test.
I set Barge In to No and now I get 60 to 90 seconds of silence then the call moves on to the call hold step.  I can't interrupt on the DTMF keypad anymore.....like it's hitting an internal timeout on the play prompt step before moving on to the next step.
Post your script so we can review, along with he wav file.
OK thanks.  I just need to get approval first....the .wav was done by a professional voice company and they probably don't want it shared for the world to use.
