Call a java class jar from within UCCX script?
jbankstonfla
Frequent Visitor
Frequent Visitor
I've written a new java class with one method that performs a calculation, and returns an int. The idea is that my UCCX 10.6 script will pass in two integers, perform the random number generator function based on these two integers as high/low, then return an int which tells me what the RNG generated.
Sooooo, I fixed the java variables for testing purposes so that only the return value is what I need to deal with at present.
I remember waaaay back in UCCX 8.5.1 you could call java from within the script, but I'm finding our that 10.6.1 has no such facilities. My Google-Fu skills are showing age, brain is near fogged up, I can'd for the live of me see how to call an external java jar from within UCCX.
Thanks, Jeff
SEAN NILSEN
Level 5
Level 5
Hey Jeff,
Here is a link to some instructions on how to get this set up in 10.x.
https://supportforums.cisco.com/document/12336156/integration-custom-java-application-uccx-100
The basic steps are:
Create a JAR of your code
Upload the JAR
Reference the Objects/Methods from a Script Element.
Hope that helps!
Sean
