CCE Lab and NFR
habib.issa
hi
there was a link that you can order a contact center entriprice lab license on line without going through the disti i used it before but i could not find the page now, kinldy if you can share the link here
thank you in advacne
ritdesai
Since evolution of smart licenses, you need to purchase the NFR for lab environment by Cisco Partners via distributor.
Follow the URL: https://www.cisco.com/c/en/us/products/collateral/customer-collaboration/guide-c07-741219.html to gain more insights. CCW requires partner level access to authenticate.
Similar post in past, https://community.cisco.com/t5/contact-center-enterprise/cce-cvp-nfr-11/m-p/3511253
thanks and regards,
Ritesh Desai
thanks and regards,
Ritesh Desai
Please mark useful if it helps you. Mark answered if it is answered.
habib.issa
Thanks for the support.
Dmytro Romaniuk
hello!
Is it possible to use A-FLEX-3-CC licenses for Lab  ? (set deployment type UCCE LAB)
@ritdesai can you suggest?
