CiscoSubdialogStartElement is not a valid voice element class.
Scope2Futue
Hi All,
Did anyone face the below error on CVP 11.6. The call fails at the very beginning of the application. We get the below error logs: -
The error was: 'com.audium.server.voiceElement.internal.CiscoSubdialogStartElement' is not a valid voice element class.
com.audium.server.AudiumException: 'com.audium.server.voiceElement.internal.CiscoSubdialogStartElement' is not a valid voice element class.
at com.audium.server.controller.Controller.goToVoiceElement(Controller.java:4158)
at com.audium.server.controller.Controller.goToElement(Controller.java:4004)
at com.audium.server.controller.Controller.enterVoiceApplication(Controller.java:1904)
at com.audium.server.controller.Controller.newCall(Controller.java:1777)
at com.audium.server.controller.Controller.doPost(Controller.java:951)
at com.audium.server.controller.Controller.doGet(Controller.java:543)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:292)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:207)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:240)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:522)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1095)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:672)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1502)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1458)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Thanks in Advance...
janinegraves
I have not, but that element isn't required. You could delete it and see if the problem disappears.
janinegraves
Was your application written and running on an older version of Studio/VXMLServer?
Did you import it into Studio and Deploy to create a new runtime version of the app? Always a good idea if possible.
You could either delete the element entirely from the app, or replace it with a new CVP_Subdialog_Start element. This element changed many, many years ago. But, as I mentioned earlier, it's pretty much optional.
