12-04-2007 11:09 PM - edited 03-14-2019 01:36 AM
I am trying to configure remote moniroting on IPCCX 4.5 - premium.
I am using just one NIC on IPCCX server and trying to use remote monitoring feature ( not VoIp spanning ).
After configring supervisors and teams etc, I stll cannot see any data on subsystems>rm-cm>remote monitoring page.
Also the monitoring and barge in buttons in supervisor desktp is grayed out.
Is there any additional steps to be done here ?
12-11-2007 02:20 PM
Try the following:
1) Verify the agent you are trying to monitor is configured as a member of the team that the supervisor is a supervisor of.
2) Make sure that you are using the correct supervisor id to login the supervisor application
3) Verify that you can establish a socket .connection between the agent and supervisor using IP address (make sure there is no NAT between the two altering the IP address).
12-11-2007 10:49 PM
Thanks for the important points.
1. Yes we have configured sup and agent in the proper team.
2.Yes we are using proper sup id.
3.This is a trial setup and all the agents and supervisor are connected to same switch, no NAT.
Is there any other thisn that I can check ?
