Bookmark
Subscribe
569
Courtesy Callback diag help
John.McCartney1
Can someone tell me what the "Retry" field means or is telling me in the attached picture? What does false mean? What about attemp1 ewt=47 reason=noresponse?
Our ContactCenter admin set it up and is no longer here and I'm trying to understand Courtesy Callback a little more. Thanks.
Mark Swanson
Level 4
Level 4
Retry basically means IF the first callback attempt was unsuccessful, then [True] the system conducts another callback attempt or [False] the system doesn't conduct another callback attempt which then, ends the callback event.
As for "attemp1 ewt=47 reason=noresponse"...
attemp1 stands for Attempt #1
ewt=47 stands for Estimated Wait Time = 47sec (unlikely 47min but that depends on your call volume, how you handle callbacks over queued calls and how many agents answer calls).
reason=noresponse, which is kinda self explanatory... a callback attempt was conducted but no one answered (no response). The callback attempt likely went to voicemail and perhaps you guys play a prompt, "please press any key to accept this callback request". Obviously, the voicemail system doesn't respond so the callback service fails due to - no response.
v/r,
Mark
Thanks for the explanation Mark, sorry for the long delay in response, I was on vacation.
