CUIC 10.5 Scheduler Problem
edumas001
Hi guys,
i have just created a bunch of Scheduled report but unfortunately when i try to modify, delete, or run them i'm getting this message :
"This scheduler is currently being updated.  Please try again later."
also the older scheduled report are acting normaly as i can edit, delete, run them.
I have run this command in cli to check the status of those reports in the DB :
run sql select id, scheduledreportname, operationflag from cuic_data:cuicscheduledreports
Everything was just fine "ready"
can someone help me out ?
Thanks a lot..
GadgetFood
Did you figure this one out I have the same issue. As all my reports shows operationflag READY.
Hi James,
Did you figure out the solution. Same case with me too.
Fazil is this occuring on the pub or sub for you?
I restarted the reporting services and tried again and appear to be functional as I ran CUIC from the pub
