Finesse 11.6 Agent device does not support Silent Monitor (CTIError=88047)
cristian.munoz
Level 4
Level 4
Hi All
From a Supervisor I trying to Start Monitoring a Agent in Talking State, but I have the follow error: Agent device does not support Silent Monitor. (CTIError=88047)
- Agent and Supervisor have Built in Bridge Enable
- Agent and Supervisor , in the line have same Monitoring Calling Search Space.
- Supervisor End User has the groups Standard CTI Allow Call Monitoring and Standard CTI Enable
- RMCM user has roles for Call Monitoring and Call Recording which is Standard CTI Allow Call Monitoring and Recording
- Agent and Supervisor have IPCommunicator
TIA
Cristian
cristian.munoz
Level 4
Level 4
Hi All
Then of perform a many check of configuration in CUCM and do not to find the origin of issue, I did decide uninstall and install the IP Communicator from PCs that failure. For my case, this solved the issue.
Cristian
