(for a project) SQL X Cisco 2023 :)
Bob420
select replace("naam","from_naam","voornaam");
UPDATE herkansiing
SET afdeling = 'schoonmaken'
WHERE ID= 2;
DELETE FROM herkansiing WHERE tel nummer='0639573920;
zoeken-wijzig-replace-delete-update
4 quarys doen in examen= CRUD- Create-Read-Update-Delete
Myql Database CRUD:
UPDATE herkansiing
WHERE ID= 2;
Create:
Create database Studenten;
create table gegevens (
UserID varchar(255),
Firstname varchar(255),
Lastname varchar(255),
Address varchar(255),
city varchar(255)
primary key (userID)
Read:
Select * from Studenten;
Select UserID, Firstname,
From gegevens:
Update:
Update gegevens
Set Firstname = ‘hans’, City = ‘Rotterdam’
Where UserID = 1;
Delete:
Delete From gegevens Where Firstname= ‘hans’;
Delete From gegevens;
Delete from Lastname;
select count (count is rij)
where
from
select count(UserID)
form gegevens1;
select * from gegevens1
where city = 'Rotterdam';
UPdate
set
where
Update gegevens1
set Lastname = 'Lobi', City = 'Amsterdam'
where userID = 26;
Delete
from
where
Delete From gegvens1
where UserID = 'jazz';
change=
select
replace
from
where
between data1, data2
(order by)
select replace("gegevens1","lastname","sirname")
from gegevens1
where lastname;
When you have a table you can use:
Insert into "table name"
values(
102868, bob, stone
This is how it is done
Bob420
values(102868, bob, stone
values(
102868, bob, stone
Bob420
Select * from "tablename" where "primary key from table or a collum" = Name ID etc;
Bob420
This might just help!!!!!!!!!
Use Databasename;
------------------------------------------ Alters the table you can ADD or Drop a column or Rename etc.
Rename Table employees TO workers;
Rename Table workers TO employees;
Alter Table employees
Add phone_number Varchar(15);
Rename Column phone_number To email;
Modify Column email Varchar(100);
Modify email Varchar(100)
After last_name;                          You could also write First
Drop Column email;
()()()()()()()()()()()()()()()()()()()() Add a column in an existing table, and insert data into that row.
Alter Table Employees
Add Column job Varchar(25);
Select * from employees;
Update employees
Set job = "Manager"
Where Employee_id = 1;
------------------------------------------ Pay attention to the datatype (for date that = year then month then day)
Insert Into employees
Values (1, "Eugene", "Krabs", 25.50, "2023-01-02");
Select * From employees;
------------------------------------------ Inserts values into an existing table.
Insert into employees
Values (2, "Squidward", "Tentacles", 15.00, "2023-01-03"),
            (3, "SpongeBob", "Squarepants", 12.50, "2023-01-04"),
            (4, "Patrick", "Star", 12.50, "2023-01-05"),
            (5, "Sandy", "Cheeks", 17.50, "2023-01-06");
------------------------------------------ Inserts values into an existing table, but this one specifies the parts that will be added.
Insert into employees (Employee_ID, First_name, Last_name)
Values (6, "Sheldon", "Plankton");
------------------------------------------ Shows a list of table employee's first name and last name.
Select First_name, Last_name
From employees;
------------------------------------------ this shows all the values from table employees for employee_id 3.
Select *
From employees
Where emplyee_id = 3;
Select *
From employees
Where first_name = "SpongeBob";
------------------------------------------ Shows the data from table employees hourly_pay higher than 15. >=
Select *
From employees
Where hourly_pay >= 15;
> can also be used solo, meaning Greater then
>= means Greater than or equal to.
------------------------------------------ shows all data from table employees hire_date Lower than 2023-01-03. <=
Select
From employees
Where hire_date <= "2023-01-03";
can also be used solo, meaning Lesser than
<= means lesser than or equal to.
------------------------------------------ AND-OR-NOT-BETWEEN-IN
Select *
From employees
Where hire_date < "2023-01-05" AND job = "cook";
Select *
From employees
Where job = "cook" OR job = "cashier";
Select *
From employees
Where Not job = "manager" AND NOT job = "asst. Manager'';
Select *
From employees
Where hire_date BETWEEN "2023-01-04" AND "2023-01-07'';
Select *
From employees
Where job IN ("cook", "cashier", "janitor");
------------------------------------------ Updates the table employees the sets the pay to 10.25 for employee that has employee_id 6.
Update employees
Set hourly_pay = 10.25
Where emplyee_id = 6;
------------------------------------------ This also updates the hourly pay but also the hiring date of employee_id 6.
Update employees
Set hourly_pay = 10.50,
       hire_date = "2023-01-07"
()()())()()()())()()()))()()()()()(  Updating from existing data.
Update employees
Set frst_name = "Smelldon"
Where employee_id = 6;
------------------------------------------ Sets the hire date to NULL, meaning that there is no data there.
Update employees
Set hire_date = NULL
------------------------------------------ This updates the hourly pay for all the employees (Or in simpler a whole column)
Update employees
Set hourly_pay = 10.25;
------------------------------------------ This deletes from table employees, employee_id 6.
Delete From employees
Where enployee_id = 6;
------------------------------------------ WILDCARD-this will show all the first names with the letter S etc.
"S%" will show everything that begins with the letter S.
"%R" will show everything that ends with the letter R.
Where first_name Like "S%";
Where hire_date Like "2023%";
Where last_name Like "%r";
------------------------------------------ AVERAGE - Shows an average from column hourly_pay or sum
Select AVG(hourly_pay)
from employees;
Select SUM(hourly_pay)
From employees;
