Get Digit String in IVR with variable string?
fgasimzade
Level 8
Level 8
Hello, everyone!
I  have the same problem, I need to have both 3 and 4 length input. With #  everything works fine, but I want to configure it without terminator to  be used by the caller.
This is what I got so far:
tranext = Extended Get String Digit
- succesfull
--if (tranext.length() == 4) then
----True
-------Call redirect
----False
--------If (tranext.length() == 3) then
-----------True
---------------- Call redirect
But it still calls only for 4 digit numbers, ignoring 3 digits.. What else do I have to do?
IPC Version
5.0(2)_Build064
Chris Deren
You need to do the "If (tranext.length() == 3) " logic under the timeout branch.
HTH,
Chris
Chris Deren
HTH,
Chris
