how to check client id and client secret valid or not
mahendra09
Which API checks if the client ID and client secret are correct?
Janos Benyovszki
@mahendra09 we do not have an integration validator API, but if you are using an incorrect or invalid client ID / secret during the OAuth process, the endpoint should throw an error about the same. If this is not the case, please show us an example and we will look into it.
