How to see programming Code for UCCX Script
hamed1900
Hi All,
How can I  see the programming Code for UCCX Script? I have a script and want to see its Code , something like :
int sum = 0;
boolean alternate = false;
boolean isValid = false;
try {
int i = 0;
for (i = ccnumber.length() - 1; i >= 0; i--) {
  int n = Integer.parseInt(ccnumber.substring(i, i + 1));
  if (alternate) {
   n = n * 2;
   if (n > 9) {
    n = (n % 10) + 1;
  sum += n;
  alternate = !alternate;
isValid = (sum % 10 == 0);
} catch (Exception e) {
return -1;
return (isValid == true ? 1 : 0);
thanks,
Hamed
david.macias
You're not going to find code per se, unless you have some java class you wrote and then you would only see the code if you had the source java file.  The script is the only interface you get for "code".
david
