ICD Script Problem
osamaokok
Level 2
Level 2
Just want to implement simple script for ICD as follows:
. check if working day
               working hours
                        select resource
               otherwise
                         play prompt " working hours from ..."
                         exit
               play prompt "Working days from ......."
               exit
exit
The attached script is exactly as descriped but when executed every thing is fine but when off hours the correct prompt is played and then the following message is played Sorry we are currently experince system problem, and unable to process you call.
can anyone help to solve this issue.
Okok
Jonathan Schulenberg
The only thing that stands out to me is that you set a different timezone. Try setting it back to the default TZ[primary] value and see if the problem continues. If it doesn't you may have run into a timezone-related defect.
Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jonathan
Thanks you are the man your answer is correct the issue was in timezone.
Ausama
