IPCC VoIP Monitor
brain_junk
I am running Cisco IPCC Express 3.5.(2) Enhanced edition for contact centre with CCM 4.0.(1). This is installed on Dedicated machine where CRA Server, VoIP Monitor and Historical Reporting is co-resident. I have configured two nic cards as described in Administration guides.
Everything is working fine but when is the Supervisor goes for call recording or Silient Monitor is doesn't work, although I can see a file created of the recording of 46 bytes in the folder
c:\program files\cisco\Desktop_config\Audiofiles\, but nothing more than that.
Note that I have already configured the switch for SPAN. I have verified my configuration with IRIS sniffer, it is working perfectly and capturing RTP packets but cannot get this successful on IPCC VoIP Monitor.
Can anyone help me in it, where I am failing, or does VoIP Monitor server need to be configured from which NIC to capture RTP packets.
SFA
pralex
Refer to the "Configure and Deploy Silent Monitoring and Record in CRS" documentation
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a00801a62a8.shtml
I have Cisco IP Softphones at the Agents and
Supervisor Desktop.
Does call recording and silent monitor is supported on
IP Softphones or IP Communicator???
SFA
hjabbour23
where did u configure port span ?
it must be on the voip monitoring server and on the port of the supervisor desktop as well
tbramwe
Level 3
Level 3
SFA:
There are known issues with some Intel Pro NICs and IPCC monitoring - check to see if yours works using the qualification process here.
http://www.cisco.com/en/US/customer/products/sw/custcosw/ps1844/products_tech_note09186a00801f42f9.shtml
If you have Intel NICs look to the bottom of the document for registry changes that may resolve the issue.
Tom
