MCS OS fix for SQL patch 2282 DB replication issue
hlaxmina
Hello Experts:
Greetings! Which MCS  2003 OS patch has the fix for the DB replication issue caused by SQL patch 2282  that is embedded in the OS SR.
My customer  doesnt want to install the OS SR which has 2282 patch that may cause DB  replication issues [eventhough there is a Cisco  suggested workaround for this defect CSCta89444], at the same time my  customer doesnt want to compromise on the latest OS bug fixes, security and  other vulnerabilities as well .
As far my understanding and investigation goes, all MCS  OS Versions starting 2003.1.4aSR8 is being packaged with SQL patch 2282 that may  cause database replication issues.
Your help is greatly  appreciated!
Many  regards,
Harish
Anthony Holloway
You will need to read the release notes for each patch.
You could always patch your OS, then manually go back and uninstall the 2282 hotfix.
