12-12-2014 01:59 AM - edited 03-14-2019 02:13 PM
System: CUCM 10.5 UCCX 10.0 MediaSense 10.5
User: Cisco Windows Jabber 10.5, CIPC 8.5.4, Cisco IP Phone
I was following the guide to know how to allow MediaSense to record calls for uccx agents, I made that part for CM configuration, but I wonder how will I allow the devices to be recorded? and how to play them back again?
can you please share the steps to configure Phones and DN to be recorded, and play the call back again?
Solved! Go to Solution.
12-12-2014 03:31 AM
kindly find the below steps
1-enable Built-in-bridge in the phone configuration.
2-create route pattern pointing to media sense Trunk
3- configure Recording profile
4- Enable Recoding in the DN level.
5- associate DN with recording profile
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/mediasense/10/srnd/CUMS_BK_MC36D963_00_mediasense-srnd_chapter_01101.html
Anas
don't forget to rate the helpful posts
12-12-2014 10:39 AM
Hi Mohamed,
you need to enable built-in-bridge in phone level, and associate recording profile and enable recording in DN level.
for playback https://<hostname>:8440/mediasense
Try it, it will work
check the below link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/mediasense/10/user_guide/CUMS_BK_MCD100EE_00_ms-user-guide-10/CUMS_BK_MCD100EE_00_ms-user-guide-10_chapter_01.html#CUMS_TK_SEC57688_00
Anas
12-12-2014 03:31 AM
Anas
12-12-2014 10:07 AM
Hello Anas,
Thanks for your reply.
I already finished that part before. But I wonder if there is something to enable from the device level (plus BIB)? or it is just for DN ?
also for playback, the user guide is talking about built in playback tool, do you know how to get that?
Regards.
12-12-2014 10:10 AM
Just for update,
i found the part of playback:
but i didn't try yet.
12-12-2014 10:39 AM
Hi Mohamed,
Anas
10-27-2016 04:13 AM
Hi Anas,
can record IP Phone CP-3905 calls by Cisco Media Sense?
Amjad
