Need to know what files should be updated with JNDI and DB connection info for Call Studio DB connection to work
Intellione01
I am working on a new install of CVP Call Studio and trying to setup the environment correctly.
Need to know what files should be updated in order for the Database element to connect to external database.  What files should the JNDI name be inserted?
I have in the Catalina_Home /context.xml, in the Server.xml, and the web.xml but not connecting.  Error: cannot find JNDI datasource
37 Replies 37
I have removed the event handler and here is the attached errorlog.
Please post your current context.xml and server.xml (again) - it can't resolve the name attribute.
Into which folder did you place the context.xml?
Thanks janine.  I did that and getting the same error: see attachment.
It's kind of crazy, but you must remove the event handler from the Events tab of the DB element in order to get the error log to display information. The easy way to do this is to do this, is to change the EventList to something like dummy.* - so it doesn't go through your event handler.
By the way, Tomcat is case-sensitive. I noticed at least 3 typo's in your context.xml with case issues:
1. type="javax.sql.Datasource"   should be type="javax.sql.DataSource"
2. minidle="30"  should be minIdle="30"
3. driverClassname=  should be       driverClassName=
<Resource
name="TELECOM_CC"
auth="Container"
maxActive="50"
minidle="30"
driverClassname="com.miscrosoft.sqlserver.jdbc.SQLServerDriver"
url="jdbc:sqlserver://TeleSTmgr_LSNR.mdco.health-partners.org:1433;databaseName=TELECOM_CC;user=;password;multiSubnetFailover=true"
thanks Janine.
I made the changes to the context.xml files. I made these changes to 2 files:
cisco/callstudio/eclipse/plugins/com.audiumcorp.studio.debug.runtime/CATALINA_HOME/Tomcat/conf/context.xml
cisco/callstudio/eclipse/plugins/com.audiumcorp.studio.debug.runtime/CATALINA_HOME/conf/context.xml
I have attached both files.
after making changes to the files, and running the debugger again, it gives same errors.  attaching error logs.
here are the files.
sorry Janine,
having a problem uploading the .xml files even when I change them to .txt.
I will just post:
this is the Catalina home conf/context.xml:
<?xml version="1.0" encoding="UTF-8"?>
<!--Licensed to the Apache Software Foundation (ASF) under one or morecontributor license agreements. See the NOTICE file distributed withthis work for additional information regarding copyright ownership.The ASF licenses this file to You under the Apache License, Version 2.0(the "License"); you may not use this file except in compliance withthe License. You may obtain a copy of the License athttp://www.apache.org/licenses/LICENSE-2.0Unless required by applicable law or agreed to in writing, softwaredistributed under the License is distributed on an "AS IS" BASIS,WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.See the License for the specific language governing permissions andlimitations under the License. -->
<!-- The contents of this file will be loaded for each web application -->
-<Context>
<WatchedResource>WEB-INF/web.xml</WatchedResource>
<WatchedResource>WEB-INF/tomcat-web.xml</WatchedResource>
<WatchedResource>${catalina.base}/conf/web.xml</WatchedResource>
<Manager pathname=""/>
<Resource url="jdbc:sqlserver://TeleSTmgr_LSNR.mdco.health-partners.org:1433;databaseName=TELECOM_CC;user=;passwordvK~JeCD;multiSubnetFailover=true" driverClassName="com.miscrosoft.sqlserver.jdbc.SQLServerDriver" minIdle="30" maxActive="50" type="javax.sql.DataSource" auth="Container" name="jdbc/TELECOM_CC"/>
</Context>
this is the Tomcat/conf/context.xml
<!-- Licensed to the Apache Software Foundation (ASF) under one or more contributor license agreements. See the NOTICE file distributed with this work for additional information regarding copyright ownership. The ASF licenses this file to You under the Apache License, Version 2.0 (the "License"); you may not use this file except in compliance with the License. You may obtain a copy of the License at http://www.apache.org/licenses/LICENSE-2.0 Unless required by applicable law or agreed to in writing, software distributed under the License is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License for the specific language governing permissions and limitations under the License. -->
<Context><WatchedResource>WEB-INF/web.xml</WatchedResource><WatchedResource>WEB-INF/tomcat-web.xml</WatchedResource><WatchedResource>${catalina.base}/conf/web.xml</WatchedResource><Manager pathname=""/><Resource url="jdbc:sqlserver://TeleSTmgr_LSNR.mdco.health-partners.org:1433;databaseName=TELECOM_CC;user=;password;multiSubnetFailover=true" driverClassName="com.miscrosoft.sqlserver.jdbc.SQLServerDriver" minIdle="30" maxActive="50" type="javax.sql....</Context>
Janine,
the error changed!  here is the error:
Caused by: com.audium.server.AudiumException: Cannot load JDBC driver class 'com.miscrosoft.sqlserver.jdbc.SQLServerDriver'
where do I get the correct driver class?
1. I use sqljdbc41.jar - but I have CVP11.6
2. The driver class name is inside the jar file.
One way to find out what yours is called, is to copy the jdbc jar file to a temp directory and change the extension to .zip
Then use Windows File Explorer to double-click and expand the .zip and keep expanding the subfolders until you see the filename with the .class extension
the full directory structure with the filename - but without the .class extension is what you use as the driverClassName (but change the slashes to dots).
3. For example, on mine, I see:
sqljdbc41.zip\com\microsoft\sqlserver\jdbc\SqlServerDriver.class
So my driver class name is: com.microsoft.sqlserver.jdbc.SqlServerDriver  (omit the class extension)
this driver class lookts like:
mssql-jdbc-8.2.0.jre8
you didn't do what I told you to do - you have to expand the jar file - the actual name of the driver class is buried inside that folder....
Janine,
I found a typo in the driver class name..corrected and now see that it can't find the stored procedure:
Caused by: com.audium.server.AudiumException: Could not find stored procedure 'GetCCEStatus'.
 at com.audium.server.action.database.DatabaseAction.doAction(DatabaseAction.java:367)
 at com.audium.server.voiceElement.ActionElementBase.service(ActionElementBase.java:390)
 ... 27 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Could not find stored procedure 'GetCCEStatus'.
 at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:262)
 at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1632)
 at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:600)
 at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:522)
 at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7225)
 at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:3053)
 at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:247)
 at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:222)
 at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:444)
 at org.apache.tomcat.dbcp.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:82)
 at com.audium.server.action.database.DatabaseAction.doAction(DatabaseAction.java:322)
does this mean I have connected to the database but not to the stored procedure in that database?
10.101.88.31.1582918420077.0.SP_ECC,02/28/2020 14:33:47.894,Database_Lookup,enter,
10.101.88.31.1582918420077.0.SP_ECC,02/28/2020 14:33:48.630,Database_Lookup,custom,num_rows_processed,0
10.101.88.31.1582918420077.0.SP_ECC,02/28/2020 --what does this mean?  this is the IP of the machine but not where the stored procedure is located. should this be the iP of the machine where the database is located?
here is the activity log.  Thanks so much for your help Janine. I don't have any help here on how to connect to external database or the stored procedure within the database.  Your help has been invaluable!!!!!  attaching the activity log.  we have made so much progress today.  Thank you.
Not sure how to connect to the stored procedure.  Should there be another configuration item i'm missing?  Should I add a Run configuration /java and add the connection to the stored procedure there and have it run before to establish connection?
