problem updating Database Schema
kking
So, I have setup a System DSN within the Server ODBC system and I have created a DSN with the same name in the Database subsystem on CRS to let my script access the DB server.
The problem is when I add the DB Read step and select properties there is no DB in the drop-down box. Clicking on Refresh DB schema yields the following GetDataSource Error: java.lang.Exception: Remote Error: java.rmi.NotBoundExeption: com.cisco.wf.subsystems.edbs.RemoteSubsystemEDBS
I must be missing something. The SQL database resides on another server but the ODBC DSN test completes sucessfully.
Any ideas?
kking
just to update, the resolution in this case was to restart the CRS Engine and retry.
