01-11-2007 03:37 AM - edited 03-14-2019 12:25 AM
Hi,all
I enocuntered one problem when I installed the System IPCC 7.0. My Media Kit is 7.0(0)B. I
followed the document to install and it was OK at first. There was one error when I should configure the IPCC Machine Initialization. When I created the IPCC Root, I created the Facility next. I pressed the creat button then I entered the name of Facility. At this time, One error displayed. It said that Failed to correctly initialize service -set service group in the Local Administrator Group. You can see the attachment for the more detail information. I have reinstalled the system, but the problem happened again. Could everyone give me some suggestion?
Any errort will be appreciated. Thank you!
01-17-2007 11:09 AM
09-26-2007 04:10 AM
I am installing the IPCC 7.0 and have the same problem as you. Have you solved it? Could you advise me...?
Michal
10-15-2007 01:15 AM
I am also facing the same problem,please anyone assist me to solve the problem.
Gnanesh.
10-15-2007 01:41 AM
I have already solved my problem. I was trying to install whole ICM on one server, including Domain Controller - and this is the "bad idea" causing the problem. DC must be on separate hardware. It is documented but I overlooked it somehow... ;-)
Michal
10-15-2007 01:48 AM
If i install system ipcc and dc in different system it will solve the problem?
gnanesh.
10-15-2007 02:33 AM
Yes.
M.
10-15-2007 02:36 AM
What are the user rights required for system ipcc installation acount.
gnanesh
10-15-2007 02:38 AM
I wass logged in as Administrator. It works... ;-)
Michal
10-15-2007 10:34 PM
Hi MIchal,
I installed succesfuly,but i am not ablt open the the deployment wizard.Before that need to start the icm services?.
Gnanesh
10-16-2007 12:21 AM
Hi Ganesh,
I am not completely sure, everything should be ready and running when installation is finished. I upgraded icm to 7.1 right after installation of 7.0 and then went to Deployment Wizard.
Michal
10-16-2007 12:30 AM
Hi Michal,
I started logger,router and distributor services,but still i am not able to login to web administration page.once click the shortcut from desktop then i am getting the microsoft enhanced security enabled.once i give ok ,displaying page cannot be displayed.
Gnanesh.
