Simultaneous Ring on 10 or more Phones
brian-white
How can I get an incoming call from multiple SIP trunks to ring on 40 phones simultaneously?  Is it possible?
Aaron Harrison
I'm not quite clear on what you mean by multiple SIP trunks - it's not really relevant. If calls are working inbound on your various trunks now, then you can do as you wish with those calls.
To make a call ring on 40 phones you can just configure a broadcast hunt group in CUCM.
I'm assuming you are using CUCM; you have posted in the Contact Center forum. CC apps are not generally designed to deliver calls in that sort of uncontrolled fashion...  perhaps describe your requirement more fully.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
