SIP Outbound calls - 404 not found
gchiarapa_value
Hi Guys!
We are facing some problems with outbound calls. When an agent makes a call, the call is established and in the middle of the call appears a SIP message 404 not found and the call drop. In extension display, appears a message dialing.
Call Flow:
Extension > CUCM > CUBE > CUSP > ISP.
Jinto Alakkal
Hi Can you post,
the output of "debug ccsip messages" and also the "debug voip dialpeer all" separately from the CUBE
Thanks!
Jinto.
Please, see attached files.
Call-ID: 14571F0E-C81411E8-AF0DB5A3-4D72A66F
Call-ID: 9F77C469-C81311E8-A22DB5A3-4D72A66F
Hi There, I was away just went through the traces could you please post the CUBE configuration have you tested whether the inbound and outbound dial peers are matching properly ?
