SQL Management Studio on UCCX 7.0(2)
marino.ventin
Is it ok to install SQL Server Management Studio on the same server that runs UCCX 7.0(2)?  Aside from a mandatory reboot, it seems like a low-impact install - just can't find anything about it in the documentation.
Marino
Gergely Szabo
technically, nothing can prevent you from doing that.
Cisco says you should not and may risk losing support.
G.
